KELMO Posted May 11, 2018 Report Share Posted May 11, 2018 Ok, so I'm about half a year late to ask this but: What did you use as a filler & sealer on the dash? I have a couple pads that could seriously use some refurbishing. 1 Quote Link to comment
sedition88 Posted May 12, 2018 Author Report Share Posted May 12, 2018 I just used a light weight filler, sanded it smooth, used a black rattle can primer, then flocked it. 1 Quote Link to comment
KELMO Posted May 12, 2018 Report Share Posted May 12, 2018 Ok, I forgot to mention you're dealing with a novice when it comes to me. Like a light weight body filler or something completely different? Sometimes I feel like a blind guy that lost his guide dog. 1 Quote Link to comment
sedition88 Posted May 13, 2018 Author Report Share Posted May 13, 2018 Haha you're good. Yes an automotive body filler that you'll be able to find at any autobody supply company. 1 Quote Link to comment
sedition88 Posted May 17, 2018 Author Report Share Posted May 17, 2018 Notches are done 2 Quote Link to comment
Charlie69 Posted May 17, 2018 Report Share Posted May 17, 2018 Those notches do not appear to be much higher than stock. 2 Quote Link to comment
sedition88 Posted May 17, 2018 Author Report Share Posted May 17, 2018 You're right, the bottom of the notch is right at the top of the stock rail. The only reason we're not doing a C notch is just in case I decide to go with a bigger wheel down the road. 2 Quote Link to comment
Charlie69 Posted May 17, 2018 Report Share Posted May 17, 2018 I understand. Nice looking notches, what dimension steel did you use? Quote Link to comment
sedition88 Posted May 17, 2018 Author Report Share Posted May 17, 2018 I actually don't know, all the fab work is being done by a friend of mine, but the notches did just slid into the frame rail, to give you some idea, so the notches are sitting inside the frame rail and welded together. 1 Quote Link to comment
sedition88 Posted May 22, 2018 Author Report Share Posted May 22, 2018 Rear end is cleaned up. A hole was found under the rust where the spring perches were and is getting patched. 3 Quote Link to comment
G-Duax Posted May 29, 2018 Report Share Posted May 29, 2018 Are those lower control tubes will take the full weight of the truck, with it being applied in the center like that? 2 Quote Link to comment
sedition88 Posted May 29, 2018 Author Report Share Posted May 29, 2018 Yes, it's been done time and time again 1 Quote Link to comment
sedition88 Posted June 11, 2018 Author Report Share Posted June 11, 2018 Getting closer. 4 Quote Link to comment
G-Duax Posted June 11, 2018 Report Share Posted June 11, 2018 What are you going to do for shocks ? Mount them on the back side of the axle, like the originals ? 1 Quote Link to comment
sedition88 Posted June 12, 2018 Author Report Share Posted June 12, 2018 Yes, going from that cross bar to the back of the axle 1 Quote Link to comment
bigboy620 Posted June 18, 2018 Report Share Posted June 18, 2018 I love seeing builds like these! Miring all day aha 2 Quote Link to comment
]2eDeYe Posted June 18, 2018 Report Share Posted June 18, 2018 Nice to see good fab work :cool: 2 Quote Link to comment
Ben_upde Posted July 19, 2018 Report Share Posted July 19, 2018 Just throwing a bookmark in here and a Hello! to a fellow treasure valley member. I’ll begin working on my recent ‘79 KC acquisition as soon as I return from vacation. ?? 3 Quote Link to comment
sedition88 Posted August 4, 2018 Author Report Share Posted August 4, 2018 Back on the lift. Had the brakes and cylinders replaced on all four corners, and front shocks getting set up. 2 Quote Link to comment
Trochu Posted August 4, 2018 Report Share Posted August 4, 2018 On 5/28/2018 at 8:21 PM, G-Duax said: Are those lower control tubes will take the full weight of the truck, with it being applied in the center like that? I was wondering that as well, then it changed to this: On 6/15/2018 at 6:20 PM, sedition88 said: Nice upgrade. Great build. Always cool seeing stuff like this. 1 Quote Link to comment
Stoffregen Motorsports Posted August 4, 2018 Report Share Posted August 4, 2018 1 hour ago, Trochu said: I was wondering that as well, then it changed to this: Nice upgrade. Great build. Always cool seeing stuff like this. Me too. I thought those were mock up control arms at first, then I saw the gussets. That will do the trick. 1 Quote Link to comment
sedition88 Posted August 10, 2018 Author Report Share Posted August 10, 2018 It's nice to know that the owner of the big truck is jealous of the little one. 3 Quote Link to comment
