fuzz's '71 510 Posted February 18, 2012 Report Posted February 18, 2012 Just got done doing the compression check and noticed I have no manufacture marks or numbers on this head. My question is, what does this mean??? I looked thru all of the records and it has never had a head replaced, so is this a screw up from the factory or a cheap knock off? Thanks. Fuzz Quote
Skib Posted February 18, 2012 Report Posted February 18, 2012 did you look on the front of the head or are you just looking on the side? 219 and 210 heads are stamped up front by the timing chain inspection cover. Quote
Boaty Posted February 18, 2012 Report Posted February 18, 2012 I have/had a semi-open head that has no markings, but is obviously a 210 due to having super small ports. You can see that it was miscast or a bad cast, as it's funky looking where there should be numbers. I think I junked it, but I'll look next time I'm out there and take a picture. :) Quote
fuzz's '71 510 Posted February 18, 2012 Author Report Posted February 18, 2012 Well skib, your right but mine looks like a 210, could just be the angle I'm looking at. So is it a good head or ???? Quote
Laecaon Posted February 18, 2012 Report Posted February 18, 2012 Well skib, your right but mine looks like a 210, could just be the angle I'm looking at. So is it a good head or ???? Its a 210 head. Stock, boring, nothing special. Small ports, small valves. Quote
Guest 510kamikazifreak Posted February 18, 2012 Report Posted February 18, 2012 Front cast 210 heads are L-16 68- early 70, they are a semi peanut head,itty bitty valves. Quote
datzenmike Posted February 19, 2012 Report Posted February 19, 2012 Only good on L16s as the combustion chamber size is about 38cc. Used on an L18 would jump the compression to 9.38. Valves and ports too small for performance. Would increase efficiency and MPG at low speeds, good throttle response... about it. Quote
fuzz's '71 510 Posted February 19, 2012 Author Report Posted February 19, 2012 It is on the L16 motor and I'm not modding anything except the carb on it, so good to go. Thanks everybody!! Quote
Guest 510kamikazifreak Posted February 19, 2012 Report Posted February 19, 2012 210 heads are paper weights also effective for holding tarps down on a wood pile Quote
Hardwyre Posted February 19, 2012 Report Posted February 19, 2012 210 on left, U67 on right. Holy shit... how does the engine even breath? Quote
TENDRIL Posted February 19, 2012 Report Posted February 19, 2012 the one on the left looks like my current girlfriends :) .... and the one on the right looks like my last girlfriends <_< Quote
nismo dr Posted February 19, 2012 Report Posted February 19, 2012 that sound you hear is crickets Quote
ggzilla Posted February 19, 2012 Report Posted February 19, 2012 I'll bet is has Nissan cast on it somewhere. Maybe if you remove the rocker cover you will see it. No company has ever done a knockoff as far as I've ever heard. Quote
fuzz's '71 510 Posted February 19, 2012 Author Report Posted February 19, 2012 I'll bet is has Nissan cast on it somewhere. Maybe if you remove the rocker cover you will see it. No company has ever done a knockoff as far as I've ever heard. It is on the front, like skibs oic. further up. Quote
