spook420 Posted February 18, 2012 Report Posted February 18, 2012 i just bought a 1970 510 wagon and the previous owner put in the ad that it was a bluebird. although it doesnt have the usually emblems of the bluebird like this. just wondering if it still is. here is my wagon. also this and this any kind of info is great! thanks spook Quote
philcas1987 Posted February 18, 2012 Report Posted February 18, 2012 what facts do you have to support its a bluebird? hearsay doesn't count. looks like a regular old 510 to me. id plates dont match a bluebird. and they look original. Quote
ggzilla Posted February 18, 2012 Report Posted February 18, 2012 All 510s are Bluebirds. Unless you mean a japan-market 510 Bluebird. Easiest way to tell is it is LHD, it's probably not a japan-market version, unless it was from okinawa. Then the engine compartment ID plate would be in Japanese. Quote
spook420 Posted February 18, 2012 Author Report Posted February 18, 2012 right that's about it. i could splat some emblem on it and called a BB. i kinda figured it wasnt. i think the ad ment that the 510 and BB were similar. you guys know theses cars better than i do. thanks All 510s are Bluebirds. Unless you mean a japan-market 510 Bluebird. Easiest way to tell is it is LHD, it's probably not a japan-market version, unless it was from okinawa. Then the engine compartment ID plate would be in Japanese. sry LHD? im still kinda new to cars and stuff. Quote
Tristin Posted February 18, 2012 Report Posted February 18, 2012 Left hand drive... meaning the steering wheel is on the left of the car. Quote
spook420 Posted February 18, 2012 Author Report Posted February 18, 2012 the steering wheel is and so is the ignition?? http://i.imgur.com/aj8Cu.jpg Quote
Laecaon Posted February 18, 2012 Report Posted February 18, 2012 Well that is stock... How mine is/was... Currently I swung mine over to the passenger side. Quote
Tristin Posted February 18, 2012 Report Posted February 18, 2012 Correct... so its a US car and therefore not a "Bluebird" in the sense that its not a JDM Datsun release. Its just a 510 wagon. In Japan (other than Okinawa), they drive RHD vehicles on the opposite side of the road than us here in the States. So if its LHD-- as yours is-- then its a US Datsun. Quote
spook420 Posted February 19, 2012 Author Report Posted February 19, 2012 cool good to know information and that there is a lot of knowledgeable people i can ask for help. thanks alot spook Quote
KyushaKai Posted February 19, 2012 Report Posted February 19, 2012 Well that is stock... How mine is/was... Currently I swung mine over to the passenger side. You moved the ignition over to the right? Is that hard to do? It always throws me off when it's on the left side for some reason, but I never put thought into moving it... Quote
ggzilla Posted February 19, 2012 Report Posted February 19, 2012 You have ignition on the dash? Mine's on the column, same location as LHD. But the turn signals always bothered me, so finally I moved it to the left side of the column. Just rotated it 180 degrees, and there was already a bolt hole there for it. Quote
Laecaon Posted February 22, 2012 Report Posted February 22, 2012 You moved the ignition over to the right? Is that hard to do? It always throws me off when it's on the left side for some reason, but I never put thought into moving it... I dont have the column surround... I did swing the assembly around the column to the right side. You loose the steering lock feature though (I bet you could make a hole for the lock...) Zilla, 510s have the the key on the column, not dash. Also the turn signal is already on the left side, and its a clamp on style, no holes for it. (note 68/69 may be different). Quote
strang3majik Posted February 22, 2012 Report Posted February 22, 2012 68/69 key is on the dash afaik Quote
