Boondocks SR. 67 PT Camaro
Ok,
heres what the boys have been watching for last few years, Ill just post pics and give you a thumb nail of whats in the build.
Drive= 355 roller motor 750 Demon all go fast goodies..pushin 460 hp, 6 speed trans
Suspension Front= fully adjustable UCA's, 750lbs Hypercoil springs, Spring bucket adjsuters, 1"x 1/8 sway bar, R&P steering, Delrim bushings, Rebuildable Howe ball joints...frame rails connectors through the pan to tie into front frame.
Suspension rear= Ford 9'' 3.73 ratio, 31 spline axles, 225lbs leafs, Watts link, shocks relocated inward . undecided on shock brand.
Brakes= Front 13" rotors SSBC 3 piston calipers CNC pedals and master cylinders, with front and rear break adjustable bias in cab
Brakes rear= 12" rotors GM metric calipers, 2.4 single piston
Interior= Arizen seats and coverd rear seat covered by same company, Corbeau 5 point retracktable harness, Ididit steering collumn, gauges all Auto meter...
Blah Blah Blah...there is a ton more of info...but here are some build pics..need to take more though.
%3ca%20href=4link7.jpg">
  • Replies 4
Ok,
%3ca%20href=belts20f.jpg">
