domn8tr Posted February 17, 2012 Report Share Posted February 17, 2012 I took the front end apart and found the grinding noise. Do I have the wrong size cylinders? I don't see a manufacturers name but there are 4 squares cast into the sides. Not sure if I got them from rock auto or fleabay. Quote Link to comment
ggzilla Posted February 17, 2012 Report Share Posted February 17, 2012 Just grind that nubbin off them so it won't foul on the drum. That is, if the brakes work OK otherwise. Quote Link to comment
datsunaholic Posted February 17, 2012 Report Share Posted February 17, 2012 Not the wrong wheel cylinders... wrong drum. The area of the drum that's contacting the wheel cyl isn't always in the same place. But you can grind that boss off, as ggzilla said. Quote Link to comment
domn8tr Posted February 18, 2012 Author Report Share Posted February 18, 2012 Just love the smell of grinding alunimum in the morning. Quote Link to comment
