1974 Chevrolet C30 Camper Special "Big Dooley"
***Smog Exempt*** 454ci Big Block V8, 4 barrel carb, Turbo 400 Trans
Camper Special (10,000 GVW)
Cheyenne Super (all options including full exterior trim, woodgrain interior, cloth headliner, door pockets, full gauge package, carpeted floor and A/C)
Dana 70 HD rear axle with 4.10 gears and factory locking diff
Biggest brakes you can get on a light commercial vehicle
Dual gas tanks
Falken tires with 80% tread
A/C converted to R134
Biggest radiator you can get
Dual batteries (one Optima included)
CD player with 4 speakers
Extendable rear bumper for camper insert
Bed Liner
Trailer brake controller
Factory chrome push bars on front bumper
Trans freshened
Motor re-furbished
Factory sway bars (1.25" front and 1.00" rear)
Dual exhaust with Flowmaster mufflers and crossover pipe
HEI distributor
K&N air cleaner
External transmission cooler
Just over 100,000 mi !!!
New Parts Include:
Mechanical fuel pump
Electric fuel pump
Radiator
Water pump
Starter motor
100 Amp alternator (12si)
Motor mounts
Fan clutch
Harmonic balancer
All gaskets and valve stem seals
Dual row timing chain
1" carb spacer and heat shield
All belts and hoses
All battery cables
Pitman arm
Sway bar bushings
This truck is a classic. It was the first light commercial dually truck you could get with a full matching bed. Every gentleman farmer/rancher had one (or wanted one) back in the day. Prices are on the rise, I saw one sell in the Midwest this last year for $9500. It has served me well for the past few years, it has no leaks, it runs GREAT! It can tow like crazy and it has the brakes to stop anything, plus it is just cool. Body is nice with some minor dents and scratches, glass is all good. Have some extra sheetmetal if interested.
Call 530-823-3316
Asking $4800
Offers considered
Located in Cool, CA
  • Replies 3
I have considered dumping it. But I have a better idea: Race car it. Leave it dually, but use lower profile tires (not too low), drop it, but again, not too low; replace the big block with a LS6; replace the TH400 with a 5 or 6 speed manual; build a cool roll cage for it; single 3" exhaust exiting out through the bedside.
TRANS AM DUALLY!!!
