WTB L16 Oil Pan From Truck
  • Replies 7
The early 620 used the same L16 truck motor till Sept. '73 and then used an L18 through '74 which dimensionally is the same as the L16. The pans should be very very close to the same as off the 521. '75 and on used an L20B which is 3/4" taller but otherwise identical. I put a car L20B motor in my old '71 521 and had to use the L16 pan and pick up so I know they fit. A truck L20B pan may also work???
Most probably a truck motor as car pans are not friendly with the front steering on the 521. That's why I said my L20B was from a car, had to use the L16 pan from the worn out motor on it. Well good to know about the pan.
The oil pickup is in the back sump of the pan so plenty of room to take a ball peen hammer and dent it in for clearance.It's only tight in the straight ahead position.
  • 2 months later...
If you check his profile you'd see he hasn't been here since ... Last Active Mar 27 2012 05:44 PM so a private message would be sure to catch him next time he logs on rather than resurrecting an old post.. This post on the other hand will drop off the board in about a day and get buried and he likely won't see it.
