Uber Deaf One Posted February 13, 2012 Report Share Posted February 13, 2012 Hey guys I'm wanting to pick up a set of 14" wheels as a set of dedicated track wheels (slicks) I would go 13s but I'm pretty sure those won't clear the 280zx brakes I have. I want to run a 205 series tire, and I really don't want to have to mess around with spacers when I switch between my street/track wheels, so I'm looking for a 0 offset wheel...... Does anyone know of any good 14x7 0 offset wheels? Quote Link to comment
datsunfreak Posted February 13, 2012 Report Share Posted February 13, 2012 FWIW, the 13x7 +0 steel Diamonds (or Barts, or Bassetts) will clear 280ZX brakes. If you're on a tight budget, these are usually about $50 each. Quote Link to comment
Skib Posted February 13, 2012 Report Share Posted February 13, 2012 got a set of slot mags comin my way Im not going to use in 14x7 in penn valley Quote Link to comment
RedBanner Posted February 13, 2012 Report Share Posted February 13, 2012 FWIW, the 13x7 +0 steel Diamonds (or Barts, or Bassetts) will clear 280ZX brakes. If you're on a tight budget, these are usually about $50 each. Aero makes a verry close copy off the diamonds, they make 14x7s and if you want they will weld them up with a reversed drop center. looks real deep that way and not every one will put it together, makes stealies realy pop imho. Quote Link to comment
Uber Deaf One Posted February 14, 2012 Author Report Share Posted February 14, 2012 I just did a little research on those wheels. At first I wasn't interested because I figured they would be really heavy, but turns out they're even lighter than my Panasports. Excellent! And $50 each is even better. And I think a 4" backspacing would be 0 offset? Am I right? Skib do you know the offset on those slotted mags? Quote Link to comment
RedBanner Posted February 14, 2012 Report Share Posted February 14, 2012 On a 7" wheel 4" back spacing is 0 offset, you are correct. Quote Link to comment
Uber Deaf One Posted February 14, 2012 Author Report Share Posted February 14, 2012 My tax refund needs to hurry up and get here!!! Thanks for all the help :) btw anyone happen to have a pic of one of those wheels mounted on a 510 with 280ZX brakes? I may just order one just to be safe.. if it clears I'll order the other 3. Quote Link to comment
datsunfreak Posted February 14, 2012 Report Share Posted February 14, 2012 Thanks for all the help :) btw anyone happen to have a pic of one of those wheels mounted on a 510 with 280ZX brakes? I may just order one just to be safe.. if it clears I'll order the other 3. 13x7 +0 Bart wheels, and 280ZX brakes. The Barts were $46 each as I recall. Quote Link to comment
Uber Deaf One Posted February 14, 2012 Author Report Share Posted February 14, 2012 Awesome! Thanks! Quote Link to comment
Skib Posted February 14, 2012 Report Share Posted February 14, 2012 Skib do you know the offset on those slotted mags? not sure there comin my way next time I see 2JZ260Z. they look like 0 offset or close Quote Link to comment
SKkeeterZ Posted February 14, 2012 Report Share Posted February 14, 2012 13x7 +0 Bart wheels, and 280ZX brakes. The Barts were $46 each as I recall. you wouldn't know the tire size and dimensions Quote Link to comment
datsunfreak Posted February 15, 2012 Report Share Posted February 15, 2012 you wouldn't know the tire size and dimensions Those are 185/70-13. Were kinda tough to install. Too much stretch for the tire store monkey to comprehend. :P A 195/60-13 or 205/60-13 is a better fit. Although they may poke out of the fender. But on a racer, who cares... ;) Quote Link to comment
datsunfreak Posted February 15, 2012 Report Share Posted February 15, 2012 Oh, and sorry. Those 13x7 wheels on my blue 4dr are Diamonds, not Barts. I had Barts on my 610. :P Look and fit the same though. ;) Quote Link to comment
