lowering
720RATSUN
How can i lower the rear of my truck. The leaf springs sit above the axle so the block would raise it if im correct??? Im just tryin to drop an inch or 2 so i can level it out.
  • Replies 4
You are also going to need the saddles for the leaves to set on. You have a 4X4? There the only ones I know of with the leaves above the axle, which one looks the most like yours?
