720RATSUN Posted February 12, 2012 Report Posted February 12, 2012 How can i lower the rear of my truck. The leaf springs sit above the axle so the block would raise it if im correct??? Im just tryin to drop an inch or 2 so i can level it out. Quote
KC Phirus Posted February 12, 2012 Report Posted February 12, 2012 put the springs under the axle then block it Quote
720RATSUN Posted February 12, 2012 Author Report Posted February 12, 2012 put the springs under the axle then block it Is there any special thing you have to do or just pull em an swap it around? Quote
KC Phirus Posted February 12, 2012 Report Posted February 12, 2012 Not so sure on a 720. Make sure you mount it above the original location. Without blocks that should give you the few inches you want. Quote
wayno Posted February 12, 2012 Report Posted February 12, 2012 You are also going to need the saddles for the leaves to set on. You have a 4X4? There the only ones I know of with the leaves above the axle, which one looks the most like yours? Quote
