720RATSUN Posted February 12, 2012 Report Share Posted February 12, 2012 How can i lower the rear of my truck. The leaf springs sit above the axle so the block would raise it if im correct??? Im just tryin to drop an inch or 2 so i can level it out. Quote Link to comment
KC Phirus Posted February 12, 2012 Report Share Posted February 12, 2012 put the springs under the axle then block it Quote Link to comment
720RATSUN Posted February 12, 2012 Author Report Share Posted February 12, 2012 put the springs under the axle then block it Is there any special thing you have to do or just pull em an swap it around? Quote Link to comment
KC Phirus Posted February 12, 2012 Report Share Posted February 12, 2012 Not so sure on a 720. Make sure you mount it above the original location. Without blocks that should give you the few inches you want. Quote Link to comment
wayno Posted February 12, 2012 Report Share Posted February 12, 2012 You are also going to need the saddles for the leaves to set on. You have a 4X4? There the only ones I know of with the leaves above the axle, which one looks the most like yours? Quote Link to comment
