620 KING CAB truck V6
MVC-006F.jpg">MVC-005F.jpg">My linkMVC-012F.jpg">My linkMVC-010F-1.jpgMVC-003F.jpg">My linkMVC-020S.jpg">My link Roof of 77 dentsMVC-019S.jpg">My link feder rust through on 77MVC-021S.jpg">My link Rocker 77MVC-004S.jpg">My link Rebuit motor trans wrote on firewall, next service 57,000,MVC-024S.jpg">My link truck has 59,000 on odometer now. Interior of the 77
MVC-023S.jpg">My link Interior of 77
MVC-016F.jpg">My link rocker 77MVC-023F.jpg">My link
interior of 77 behind seats
MVC-015F.jpg">My link bed side seem 77
MVC-019F.jpg">My link engine 77
MVC-022F.jpg">My link interior 77
MVC-005F-2.jpg">My link
MVC-007F-3.jpg">My link
MVC-005F-1.jpg">My link
MVC-007F.jpg">My linkMVC-010F.jpg">My linkMVC-020F.jpg">My linkMVC-024F.jpg">My link interior 78 hot rod
MVC-004F-1.jpg">My linkMVC-014F-1.jpg">My link
UPDATE 2/20/12 THE STOCK BLUE 77 IS SOLD! A happy datsun fan!
I still have all the parts with the hotrod for sale.
I Built This Truck as a old School Hot Rod!! What you could build in 1978 I built in 2005
JDM Mad Blade 3 piece lightweight racing wheels these were NOT sold in the USA! VERY RARE!! I've had em from 05, Are very good to excellent condition for about 20 years old? these wheels alone are worth about $2000!? I searched and searched the internet for more of these wheels (for a spare) I could only find 2 a guy had in Europe he wanted $400 a piece for them, He would not sell only one and they were not in that good of condition. BFgoodrich 225/60/15 traction TA tires 40-50%? tread left on them
I'm asking $5500 FIRM!! for the hot rod........ SOLD! the stock 77
NOTE!!!!! This is a factory AIR conditioning truck and still has all the factory parts in the truck, Except for compressor it needs some custom mounts welded up and installed cleaned, charged, etc, and you'll have AIR!!
If you buy the Hot Rod you get ALL the NOS parts that I have to go with this factory air 78 custom V6 swap, Parts that I have been collecting for years are and will go with this truck and only this truck WILL BE included with sale of the 78 Hot Rod truck. $5500.00 CASH FIRM!
I have owned the 78 for almost 20 years been saving parts for the paint job the truck needs. I have and nothing wrong with the parts on truck now.... 2 NEW fenders, (fenders are good on the truck) 2 NOS fender plastic liners (these are always broke, gone, or missing on the 620 datsuns the 78 STILL! has the original ones! on it and I also have a NOS set of them. VARY RARE!
I have a new LOF tinted windshield, it's the best quality one, outer door window weatherstrips, door bumpers, hood bumpers, visor holders, dome light lens, rear window weatherstrip, set of new brake drums with shoes, springs, and rear wheel brake cylinder kit, set of rebuilt disc brake calipers for the hot rod, (brakes are good on truck now) A new NOS heater control valve, A set of euro tail light lens(all lenses good on the truck, fronts on it now are (new NOS). 4 brake adjuster rubber boots, New NOS wiper linkage bushings, A plastic dash cover. The 78 has a new front bumper on it (one piece, no seems! have all new NOS bumper end mounting hardware parts) new NOS front turn lenses I rebuilt most of the frontend on the hot rod...the tie rods, bottom ball joints, center link, idler arm, all front end parts that I could do when off the truck, were cleaned and painted, Engine compartment looks very nice.
The hot rod 78 has a healthy rebuit 1979 buick 231 C.I. 3.8 LT. Engine has all new parts bored .30 over, 9.5 to 1 CR, ARP rod bolts, Polished crank with standard main, .001 oversize rod bearings, Rhoads lifters, new push rods, timing chain healthy cam, minor port polish gasket match to heads and Edelbrock performer manifold with 500 cfm weber/carter carb, $400 custom dual exaust with crossover pipe, dual Raptor mufflers, custom built $130, 5 quart deep sump oil pan, high torque chevy mini starter, A Bowtie Overdrives of Ca. 2004R lockup torque converter overdrive Stage II performance built $1300 transmission, B&M shifter, Custom drive line, $430 BECOOL aluminum radiator, remote radiator cap overflow tank, 2 electric fans, 2 trans coolers, 1 trans intercooler, custom transmissions lines, Tach, 2 water tempgauges on it, has A $125 adjustable water temp switch gauge for the second electric fan. truck runs 205 210 but never overheats. has a vacuum gauge, A trans temp and even a transmission pressure gauge! I was not going to burn up $2000 Engine or $1300 trans! 1"aftermarket front anti-sway bar, notched and modified crossmember, I have a new in the box 5/8" rear anti-sway bar(not installed) Truck handles very nice at speed more like a sports car than an old datsun truck.
The hot rod is a blast to drive! it's a real sleeper! I live in mountain country built this truck as a highway cruiser, it runs out real nice! it's quick and it's fast!
I have done alot of custom work installing this engine right and it looks good too! just to many little things done to go over all them best to call if you really want all the info on what I've done to this truck. I have over $7,000 in this truck building it. Took me 8 months of figuring and fabricating to make everything work. I have kids tell me they will just build their own? you can't do it any cheaper and get the truck I have built. There are still many things on both these trucks needing finished etc. 78 needs new (included) buick stock engine mounts bolted up to engine and adapter mounts that are shimed and bolted together now welded up. Trans mount on 78 needs re-done differently (have plans) I drive them daily with ZERO problems. The hot rod has disc brakes front and all in good working order
my number is 541 274 9427 if you like to hear either of these trucks run? you can call on the phone hear them? the hot rod has a real nice rumpity rump idle to it! once it warms up!
The paint is SHOT does need a paint job has dents, dings, scratches. etc. will need the minor body work and paint. both truck run great and is a daily driver and mechanically sound, minor problems to fix on it. I got everything working just need the fine tuning of a few things, needing fixed, finished, re-done etc The seats in the hot rod are held together with duct tape, some extra foam and have 3? layers of cheap seat covers on them, they need seat covers on them anyway but the seats need reupholstered. the Hot rod I've have for 20 year new/er carpet are very clean inside, painted dash, panels, et, etc, with correct plastic/vinyl paint, Both are daily drivers so have some wear.
I posted more pics showing the dinged and rusted back bumpers, the thin paint and surface rust on the roofs of the trucks, I'm trying to show you the worst of the problems with these trucks. All original paint except for some fender and door touch ups, so nothing serious being hid with bondo and new paint, What you see is what you get. The 78 hot rod is in good condition, has 300,000 on the truck but low miles about 12-15 thousand in 7 YEARS! on the V6 with regular oil and air, fuel filters. etc, etc,
The glass in the 78 is all good windshield has a small bullet under passenger wiper (new winshield with truck) minor scratches on door glasses etc. and the back window of the 77 has some burn spots, pitting, from welding slag hitting it from someone cutting or welding on something sitting in the bed of the truck have some mild to mederate rust in it, normal amount, nothing severe. I do have one good back bumper, it's a black painted one was going to put it on the hot rod insted of the chrome, hot rod is black and blue! can include with a truck/s.
  • Replies 39
Assuming you have a Photobucket account, (which is free by the way) scroll over your picture you want to post, when the various link pop up bellow your photo, mouse over the "IMG Code" and left click, it will automatically copy the direct link. Now, go back to Ratsun, and right click, left click on paste. You have now successfully posted a link to your picture that will show up as a picture. There is no need to use any of the stuff on the top of the posting window.
I would recommend hitting enter before posting the next picture. It makes it easier to add text between them after you have them loaded here.
First.
Glad you figured out how to post pics.
Second.
Getting into a pissing match with the guy that posted instructions on how to post pictures is retarded.
Third.
KC Phirus... stay the fuck out of the classifieds unless you are actively selling or purchasing an item. If I see this shit again you will be permaband!
  • Like 3
2eDeYe' date='12 February 2012 - 05:49 PM' timestamp='1329097752' post='633148']
Sorry Izzo...that shit was in the middle of... I don't even know what to call that bitch fest. :rolleyes:
It happens and figured it was due to the bs.
Awaiting response from op
Where did my post go? It had legitimate questions in there...
Is it a four ir five speed? (The 77) happen to have disc brakes?
Points or electric dizzy?
I see admin cleaned up the mess.
picking on the new guy was fun?
KC I guess did send me address to view help info but didn't explain anything to me. Not familiar with how the site woked, my learning is over. thanks everyone for the help.
the 77 is a 5 speed, drum brakes, electronic ign.
The previous owner took good care of this truck. has a hole in muffler, turn signal does not cancel on it own, minor little things like that but the truck is mechanically sound.
Guest 510kamikazifreak
Thanks whats my chances of selling? you know the site, do you think I'm going to need more than luck? am I being realistic? I see stock king cabs in good shape going for $4000
The right buyer is out there,especially for clean trucks like these.
may take a little bit but it will happen :)
Those are two nice 620's there. Hope they sell quickly. What other 620's do you have? And whay are you selling them?
Larry
I have thought about craigslist and do use it, problem with listing only one area.
Fee bay and payup pal I don't like anymore
I have 3 other 77 kingcabs they all DO RUN various state of problems, fixeruppers, $400? for your pic of two of 5 speed trucks and I have one that is an automatic trans truck best condition of the 3 fixing things on it now (carpet, cleaning, tuning, etc.) as it is now and cash $500? fixed and running with tags $900? I have titles for all trucks only ONE transfered and in my name, one of the 5 speeds the auto trans truck I have title just not transfered into my name DMV fees of course.
I have one standard cab truck is a rolling shell with good motor trans etc. needs put together or for parts resto started never finished good project truck and have tilte it's a 1976?
List it in multiple areas. Can use one account for your areas and surrounding then another for a different location and surrounding areas. Can you figure it out without raging?
The hotrod is worth posting in different states.
Did you throw down some sound proofing before you put in the carpet?
How were the floors, and bed seems.
1500 is the asking price? Is it or best offer?
info is for the 77
Floors were not bad corner of driver door post are had rust through spot I cleaned and stripped the rust, filled a hole in with silicone to seal out water. (fender has rust through spot in same area) painted the floor boards, Double layer of aluminum foil (heat reflectant) new 6lb foam home carpet type pad and new carpet, back panel is carpeted (in pics) carpet is blue.
Bed seams have some minor to average rust, not bad. Trucks don't rust bad around here it's to dry.
open to offers
Can you get me some good photos on the 77?
Interior shots, engine bay, all sides and of the rust. If its not to much trouble that is... I'll send you a PM also.
3rd and 4th pic down is the engine bay and interior of the 77
I will not go into taking alot of pictures of rust they just don't do it justice! pics don't show how bad the paint is on these trucks. Same as rust! I can take a picture and you really can't tell how bad or good it is..... been there done that! I used to own 12 cars! had beside these datsuns. A 76 datsun converted to 4x4, 72 camaro SS, 73 camaro, 69 coronet RT, 66 bevedere II, 72 duster, 73 road runner, 70 valiant. you think I have not taken a few pics? try as you might they never show good enough detail.when it comes to try showing bad.
It's a 1977 do the math, has some rust..
