datsun 510 with 280zx brakes
Bone831
  • Replies 10
Bleed the brakes. My stock calipers did something similar when I first started filling them up.
Also get a 280z master, NOT 280ZX. They are much better for rear drum brakes because the 81 master cylander is designed for rear disc brakes which I've heard can 'overpower' rear drums.
  • 1 year later...
other way around, it'd underpower the rear drums.  if I remember what I was told by wayno correctly, disc brakes only need about 3 pounds of pressure to work. drums need about 10-12 since they don't sit directly on the brake like a disc pad does.
Gees just swap the residual valve from the drum master into the ZX or Z, (although I don't see why you would run a 7/8" z master on larger zx calipers that came with a 15/16" master)  rear master. Done and done. I put a 15/16" ZX master in my 710 because of the larger Maxima calipers. All I did was put the 710 rear residual valve in it. Good to friggin go!....
cause a 7/8 is sufficient, and you don't need to swap any residual valves.  i'm still runnin a 3/4 on my 510 goon with rear discs from a 200sx. stops me just fine lol.  I might have to go to a 15/16 on one of my 710s tho. just thinking of it mike, was it goon or sedan struts/brakes you swapped on, or would it really matter?
I'm running a 15/16" ZX MC with 280zx front struts/brakes, and stock 510 rear drums.  All 4 wheels lock up at about the same time.  I've had people drive my car then say oh no the brakes don't work.  They work, you just have to press them a little harder.  I prefer manual brakes, I hate locking up tires with just my big toe resting on the pedal...
This MC will be perfect when I get the Maxima calipers on the back.  Just got to make my own brackets...
