Tight outside door handle
josh817
As the title says... My driers side door handle was tight when I was getting my truck together. I greased the latch thing in the door jam, and it works lovely. The passenger side though... not so lucky! The handle is verrrryyy tight and I worry about the outside handle. When I was going in and out of the truck a lot on the side, all the tugging and yanking eventually broke off the swing arm on the handle. I replaced the handle and I try not to use it until I can figure out how to resolve the problem.
Does the latch in the door jam need to be adjusted outward or something? It got tighter/worse when I put in my door seals.
  • Replies 3
