Where to get new mounts?
Oliver
  • Replies 5
Here are engine mounts for a datsun 520 with the J13 engine, these will work as long as the J block engine mount hardware was used on your conversion, if the E1 block hardware was used to mount your J13 engine, then I have not a clue what to tell you.
http://www.ebay.com/...=item5647536c61
Now I am not saying that this is a good ebay seller, he/she is rated 99% positive feedback, but this one also does not except returns on some goods.
I will try to say this the best I can, the photo with red in it is my 1964 NL320 with an E block(1200), notice how the motor mount is angled , and the motor mount mounting surface is up and away from the fuel pump/fitting.
Now look at the other photo without red in it, see how the motor mount mounting surface is near the fuel pump/fitting, and is angled flatter, this is my early 1966 datsun 520 with a J block in it.
