Z chopper Posted January 28, 2012 Author Report Share Posted January 28, 2012 I was watching it and who ever did get it got one hell of a deal Quote Link to comment
Z chopper Posted January 28, 2012 Author Report Share Posted January 28, 2012 I think I am gonna look into the throttle body conversion by patton machine, if I can't find an L18e manifold for reasonably cheap Quote Link to comment
merlin Posted January 28, 2012 Report Share Posted January 28, 2012 The patton machine version is coool, but it is very very expensive ...its really designed for british car guys who don't want to give up the look of SU's or strombergs under the hood. Its designer fuel injection... You're paying as much for style as you are for function. Here at Ratsun, we pay for function, but we rattlecan our style. Quote Link to comment
Sealik Posted January 28, 2012 Report Share Posted January 28, 2012 If you are going to make a manifold for the L20B/L18/L16, most guys use the S110 ECU. They come with either O2 sensor (1982-1983) or without (1980-1981). Guys have used S110 ECU successfully with these manifold/factory EFI setup for 1200cc-2200cc Datsun engines. Yeah....I'm using one on a Z24...works rather well. Just had to re-adjust the clock/spring a bit for less tension/more fuel Quote Link to comment
Guest 510kamikazifreak Posted January 28, 2012 Report Share Posted January 28, 2012 http://www.usedcowichan.com/classified-ad/1982-Datsun-200-SX_13255285 This was for sale a while back.Maybe it sold, maybe it didnt,use the report ad function,and send them a message you are trying to see if it sold or not,they may give you contact info for the seller. :sneaky: Quote Link to comment
ggzilla Posted January 28, 2012 Report Share Posted January 28, 2012 MegaSquirt is much more versatile. It's a first rate ECU. The only reason to use a factory Datsun ECU is for cheap, or if you like the 4-wire hookup. Quote Link to comment
Z chopper Posted January 28, 2012 Author Report Share Posted January 28, 2012 http://www.usedcowic...200-SX_13255285 This was for sale a while back.Maybe it sold, maybe it didnt,use the report ad function,and send them a message you are trying to see if it sold or not,they may give you contact info for the seller. :sneaky: but would this have an L series or Z series engine Quote Link to comment
Sealik Posted January 28, 2012 Report Share Posted January 28, 2012 but would this have an L series or Z series engine Most likely a Z22E Quote Link to comment
ggzilla Posted January 28, 2012 Report Share Posted January 28, 2012 Yep, that ECU can and has powered many old-school Datsun engines. Quote Link to comment
Sealik Posted January 28, 2012 Report Share Posted January 28, 2012 Yep, that ECU can and has powered many old-school Datsun engines. Yeah...I'm impressed with that EFI. 30 below...and if the battery isn't dead the Z24E will flash right up :D ...and idle by itself within a couple of minutes. Of course that's with no air regulator/choke.... :cool: Quote Link to comment
Jester Posted January 29, 2012 Report Share Posted January 29, 2012 Just wondering how an'84 200SX, CA20E equipt, ECU would work out for this? I have one sitting in my garage. Personally, I like the idea of having the O2 sensor in the system. What's the point of having EFI if it doesn't do what it was intended for? Quote Link to comment
Laecaon Posted January 29, 2012 Report Share Posted January 29, 2012 Just wondering how an'84 200SX, CA20E equipt, ECU would work out for this? I have one sitting in my garage. Personally, I like the idea of having the O2 sensor in the system. What's the point of having EFI if it doesn't do what it was intended for? I think it would work well. One of the threads linked to earlier, Icehouse mentions that (at least the KA ECU) only reads a few things, "Air volume, air temp, engine temp, throttle posistion. And rpm. Nothing about displacment." And the same thread is where the KA dizzy was attached to the L20 cover. I then wonder how similar the CA dizzy(?) is and if you can swap over the encoder wheel thingy. I know I saw a thread of FJ and SR wheels being swapped, or some other motors, I dont remember. Quote Link to comment
koback68 Posted January 29, 2012 Report Share Posted January 29, 2012 Jeff built my manifold from scratch and i cant thank him enough.(google daves datsun 510) Im shur there's a different way to bring it up Quote Link to comment
WAGON JON Posted January 29, 2012 Report Share Posted January 29, 2012 Here it is... http://community.ratsun.net/topic/4574-daves-datsun-510/ Quote Link to comment
Z chopper Posted January 29, 2012 Author Report Share Posted January 29, 2012 Jeff built my manifold from scratch and i cant thank him enough.(google daves datsun 510) Im shur there's a different way to bring it up that would be this one right http://community.ratsun.net/topic/4574-daves-datsun-510/page__p__59953__hl__%2B+%2Bdaves+%2Bdatsun+%2B510__fromsearch__1?do=findComment&comment=59953 Quote Link to comment
ggzilla Posted January 29, 2012 Report Share Posted January 29, 2012 The purpose of EFI is not to read an O2 sensor. Datsun made lots of EFI system without O2 sensor. But certainly the closed loop system can fine-tune the engine while it is running so it is better. The problem with the new ECUs is they use a cam position sensor (mid-80s ones fit it into 360-degree sensor wheel in the distributor). Datsun engines didn't have such a thing. Quote Link to comment
Z chopper Posted January 29, 2012 Author Report Share Posted January 29, 2012 hmm this thread seems to be going into the technical, might have to search a tech write up about Fuel Injection L series engines. Or if there isn't one maybe someone could write one Quote Link to comment
DAT510 Posted January 29, 2012 Report Share Posted January 29, 2012 Right is 200SX Z22E ECU.. it was under the driver side kick panel yo Quote Link to comment
Ranman72 Posted January 29, 2012 Report Share Posted January 29, 2012 Mine I did 10 years ago And another one I did just last summer both super clean looks factory nice job John Quote Link to comment
WAGON JON Posted January 30, 2012 Report Share Posted January 30, 2012 that would be this one right http://community.ratsun.net/topic/4574-daves-datsun-510/page__p__59953__hl__%2B+%2Bdaves+%2Bdatsun+%2B510__fromsearch__1?do=findComment&comment=59953 Yeah the s a m e link I just posted...... Thanks Ranman. Quote Link to comment
Z chopper Posted January 30, 2012 Author Report Share Posted January 30, 2012 ya that is cool but I am looking for the OEM look Quote Link to comment
ggzilla Posted January 30, 2012 Report Share Posted January 30, 2012 This is the OEM look. It's orignal Datsun efi parts: Quote Link to comment
Guest 510kamikazifreak Posted January 30, 2012 Report Share Posted January 30, 2012 Get that 510? If you did the 200sx is the best parts rig,brakes, efi stuff, if it happens to be a z20e in canada should have the matchbox dizzy. Quote Link to comment
Z chopper Posted January 30, 2012 Author Report Share Posted January 30, 2012 Get that 510? If you did the 200sx is the best parts rig,brakes, efi stuff, if it happens to be a z20e in canada should have the matchbox dizzy. the guy who owns the 510 is in Vancouver and I have emailed him a few times about paying and getting a bill of sale but no response Quote Link to comment
Guest 510kamikazifreak Posted January 30, 2012 Report Share Posted January 30, 2012 the guy who owns the 510 is in Vancouver and I have emailed him a few times about paying and getting a bill of sale but no response Did you go see it? Quote Link to comment
