521 cutting party
dirtydiesel
okay every one in shomish county area listen up ! !!! i am going to host a cab cutting party at my house on saterday jan 28th in everett... bring your cutting tools or special window removal tools. and get cab peice off my 521 for cheap prices...
rules
_ safety glasses and gloves are required
_ first come first serve_
_bring your own tools_
_ beer is the only substance allowed on the premises_ if said beer is brought it must be generiously shared_
_ pick up yor mess_
_ and be respectful_
_ i am not responcible if you injure yourself or some one else._ but hospital is four blocks away ...
party starts at 10 am and finishes at 3pm
prices are from $ 10_ $40 depending on size of peice.
for location call _ diesel @ 425-210-4975
general idea of location everett community college on 9th and colby ave everett washington 982012011-06-04023241.jpg
  • Replies 30
I'd love to buy the following if possible:
column turn assembly switch
flasher switch
steering wheel
turn switch i sold already
steering wheel isnt that great- TXT ME AND ILL SEND YOU A PIC
ill double check on that flasher i dont remeber if that is part of the turn switch
Do you have the steering shaft rubber that goes into the firewall.Its oval and its were the shaft goes right through the firewall.Thank you
get a piece of rubber or similar material, cut out the teardrop shape using the old one as a template, cut a circle in it for the column, and your done!!!! anyone you find will likely be crusty!
