chopderek Posted January 21, 2012 Report Share Posted January 21, 2012 Is the pattern 4X100 0r 4X114? I am looking for wheels and I don't know what will fit.There are so many people listing different sizes I'm confused!! Thanks Derek Quote Link to comment
H5WAGON Posted January 21, 2012 Report Share Posted January 21, 2012 4x114.3....most list as 114...:P 4 x 4 1/2 Pack spacing is the fun part.:D Quote Link to comment
Xander_42 Posted January 21, 2012 Report Share Posted January 21, 2012 This is a good place to start. http://kmhafer.datsu.../wheelchart.htm My experience with aftermarket wheels and sedans is that you can go from 13 to 17, but I think anything bigger than 15 looks weird. You can go up to 7" wide easily (without flares), I would recommend going with roughly a 0 offset wheel and 280zx struts or a little higher offset if using the stock struts. One thing to consider if you are unsure of wheel fitment is you can always space up from a higher positive offset, but if the offset is too negative, there's not much you can do (excluding 280zx calipers which bring the front track in a bit). Edit: Damn, forgot to say that this information is readily available, and you should have searched a little harder before starting a new thread. Edit 2: I was running the 15x6 87-88 Maxima wheels, they had +44 offset, and I was running 12.7mm (.5") spacers (which makes it +31.3mm offset). With this etup, the wheels were fairly pulled back (narrow looking track, especially in the back). Now I've got some 15x7 +0 Konig Rewinds on the car, with 205/50 Direzzas, on it. The fronts are poking out a bit, necessitating 280zx struts (or higher offset wheels). The rears are just about perfect, but I am going to need to raise my ride height a touch, and roll the fenders. Very termporarily I had some of my GSL-SE RX-7's wheels (14x5.5 +42) on the front of the 510, I believe I had to run a full inch of spacers to keep something from rubbing, but I don't remember what or why. Quote Link to comment
ggzilla Posted January 21, 2012 Report Share Posted January 21, 2012 You can go up to 7" wide easily (without flares) ... depending on the tires you fit. Quote Link to comment
Laecaon Posted January 21, 2012 Report Share Posted January 21, 2012 I have seen 7.5 in the front, it was flush... Quote Link to comment
Guest kamakazi620 Posted January 22, 2012 Report Share Posted January 22, 2012 I have seen 7.5 in the front, it was flush... HerraFrush????? Quote Link to comment
