ggzilla Posted January 24, 2012 Report Share Posted January 24, 2012 Thanks. Geo Metro rack ... The pivot points are at +/-23" Too long then for a 510. You can easily lengthen them (the pivot points screw in), but to shorten involves cutting and modifying the rack. Here's the Metro ends, you can see there is no room to shorten the pivot points. Well maybe you could shorten 1/2 inch??? Quote Link to comment
HRH Posted January 24, 2012 Report Share Posted January 24, 2012 I've decided this project will require much more time than I thought, so thinking I'm going to renew my interest in putting the 210 box back together and putting that in the 510 instead. I'm already running out of time to do stuff to the car before Canby if I really want to drive it there. Quote Link to comment
DRIVEN Posted January 24, 2012 Report Share Posted January 24, 2012 Too long then for a 510. You can easily lengthen them (the pivot points screw in), but to shorten involves cutting and modifying the rack. Really? I measured it at about 1/2" wider than the LCA points in my car -- pretty close. Isn't a control arm length equal to the length of the tie rod and on the same plane horizontally considered ideal to optimize geometry? Here's the Metro ends, you can see there is no room to shorten the pivot points. Well maybe you could shorten 1/2 inch??? I was actually referring to the overall width. There is plenty of room to shorten the rod between the pivot and the threads or cut it off and graft in the 510 outer tie rod end. Sorry if I was unclear. Quote Link to comment
ggzilla Posted January 25, 2012 Report Share Posted January 25, 2012 The control arm length is minor. You can easily lengthen or shorten the tie rods to match. More important is the length pivot-to-pivot. 1/2" wider will give you bump steer. But perhaps you could grind 1/4" off each end of the rods and still have enough to screw back on and be safe. Quote Link to comment
DISLEXICDIME Posted January 25, 2012 Report Share Posted January 25, 2012 s12 rack Quote Link to comment
DAT510 Posted January 25, 2012 Report Share Posted January 25, 2012 83 200SX? the steering box looks similar to the 510... Quote Link to comment
DISLEXICDIME Posted January 25, 2012 Report Share Posted January 25, 2012 i said rack not box Quote Link to comment
DRIVEN Posted January 25, 2012 Report Share Posted January 25, 2012 s12 rack Was there a manual version or were they all power? Quote Link to comment
ggzilla Posted January 25, 2012 Report Share Posted January 25, 2012 S12 (1984-1988 200SX) came with power steering option or manual steering. The V6 model did not offer manual. Quote Link to comment
DAT510 Posted January 25, 2012 Report Share Posted January 25, 2012 does anyone have measurements on the S110 steering rack? if not i'll measure it tomorrow. Quote Link to comment
ggzilla Posted January 25, 2012 Report Share Posted January 25, 2012 Please measure the pivot-to-pivot length, which is far more important than the overall width. Quote Link to comment
DAT510 Posted January 25, 2012 Report Share Posted January 25, 2012 Please measure the pivot-to-pivot length, which is far more important than the overall width. Can i measure it while it's still in the car? and the pivot i presume is the end that looks like a ball joint? Quote Link to comment
thisismatt Posted January 25, 2012 Report Share Posted January 25, 2012 The width from center of joint to center of joint inside the dust boots - the inside joints of the tie rods. Quote Link to comment
DAT510 Posted January 26, 2012 Report Share Posted January 26, 2012 I went to measure it and it wasn't rack and pinion.. it was instead a mechanical set up.... still it the steering box intrigued me.. what if you could swap this one for the 510 and have power steering? looks similar to this Quote Link to comment
ggzilla Posted January 26, 2012 Report Share Posted January 26, 2012 Looks similar to the 620 steering gearbox. But doesn't look like power steering. Mechanical rack & pinion steering gearbox is what I want. No power steering for me as more complicated which means less reliable. Quote Link to comment
DAT510 Posted January 26, 2012 Report Share Posted January 26, 2012 It's not that exact one... i'll snap a pic tomorrow. Quote Link to comment
BoostinBen Posted January 26, 2012 Report Share Posted January 26, 2012 Just got a measurement for an Mk1 rack from a buddy... 525mm ..21" pivot to pivot. I think I might give that a go, but I will have to verify that info when I go check it out in person .. Quote Link to comment
ggzilla Posted January 26, 2012 Report Share Posted January 26, 2012 Ford Escort MK I? I've seen a Datsun which used that steering rack. Quote Link to comment
BoostinBen Posted January 31, 2012 Report Share Posted January 31, 2012 Ford Escort MK I? I've seen a Datsun which used that steering rack. I was referring to a mk1 vw .. I have one up in Sonoma at my buddies house I can have I'm going to check it out this weekend I'll post up pics and measurements.. I might hit up pick n pull for some investigation as well. Quote Link to comment
paramedicopace Posted February 14, 2012 Author Report Share Posted February 14, 2012 Smartcar rack looks to be the smallest rack i've seen but have no measurements found. MK1 is a great idea as well. Power would be nice and make the 510 just that much easier to slam around. The search will continue. Quote Link to comment
mike Posted February 14, 2012 Report Share Posted February 14, 2012 Sorry I have no info to add on the rack, but has anybody looked into electric assist? Hydraulic power steering seems like it would be a power robbing SOB especially if youre running an L... Quote Link to comment
thisismatt Posted February 14, 2012 Report Share Posted February 14, 2012 Sorry I have no info to add on the rack, but has anybody looked into electric assist? Hydraulic power steering seems like it would be a power robbing SOB especially if youre running an L... Yes, Goichi1 on the realm added electric assist to his bluebird coupe. Quote Link to comment
BoostinBen Posted February 14, 2012 Report Share Posted February 14, 2012 Got my MK1 rack... Ill make some accurate measurements and post pics tonight.. Quote Link to comment
