Fj20et Dizzy Modded For S14 Ecu
Ant-dat
here are the pictuers of the FJ Dizzy that i have converted so that i can use it as a CAS and put out signal to a S14 ecu
S14 CAS disk
FJ20et disk
FJ20et and S14 disk (inner notches are differet and over all diameter)
FJ20et Dizzy
Using the FJ20ET disk as a guide to drill S14 one (make sure you have it correct way up )
Modded FJ20et dizzy
signal out put is the same as the S14 one which is great (even thought the disk is a little smaller it works)
I had to drill the S14 disc so that i could use the FJ20ET spacers and rotor arm spindal (for lining up to TDC)
You now have a FJ20ET dizzy ready for S14 ecu
Then i constructed and wired up the coil packs using S13 coil packs with little modification and S13 loom that plugged right into the S14 loom with no modifications
  • Replies 3
  • 6 years later...
