Duncan's 71 "Oz" Goon
Duncan
So once again, 510 experts: How far down the fender do I roll the inner edges.  Right now, I rolled the front part to about where the front bumper meets the fender, and the back is at the same height.  Should I roll it all the way down, or is this far enough?  Don't want to do all this, then find out it's wrong after it's painted..
Honestly, I only do about 10-12" of it. You already went "too far"...   ^_^
  • Replies 1.8k
'90s Nissan Quest rears, same size but 10mm longer.
I got 280zx rear studs.  They are about 10mm longer then the fronts.  They had SO many applications listed for them, I think these are probably the same ones used on the Quest.
I might bend them back then :)
Yanked the fender off today..
Spent about ten minutes and corrected my "over rolled" fender edges.  Thanks for the advice, John!
This actually went much better than I thought it would.  I have the gap pretty uniform at around 3/16", and it didn't take too much time.
It's difficult to use a grinder on metal and get a uniform edge, so I widened it, then used 1/8" solder to lead the edge of the fender.  The lead is soft and easy to file, so it went better than I expected.  I wasn't sure if I could use lead on the narrow edge, but it worked fine using 1/8" solder.  I have one of those 140 watt Weller soldering guns that is probably terrible for soldering electronics, but it's great for doing small repairs and things like this on car bodies.
Other than some fine tuning tomorrow, the major work is done.  (Other than repaint, of course)
  • Like 3
Put my longer wheel studs in today.  It went much smoother than I imagined.  I still have the steel wheels from my old Sunny, so I used one to attach the hubs to for breaking bolts loose and to torque them down.  Worked out great.
That special tool on the right is actually a "tapered cylindrical caliper stand" and not a bucket. It was specially designed to hold a detached caliper safely so the hydraulic line doesn't get kinked or loosened.  It's a highly specialized tool, and you'll only find them in more upscale repair places.
  • 4 weeks later...
Been a while since I updated my thread..
Got the fender gaps done.  The passenger side couldn't be better.  The driver's side is still a bit close and I may redo it.  It won't happen this month or next month.  It was a shit load of work and I'm really sick of bodywork and paint right now...
Still need some advice from my Ratsun buddies...
I know the rear of the back seat is painted a light grey.  Fortunately, the PO left it as it was.  The seat bottom and the hinges were rattle canned dark grey. (Like damn near everything else in the car)
It's getting near time for upholstery, and I'm going to have the upholsterer remove all the seat covers.  Once they are bare, I want to repaint them.  I'm thinking the light color might really stick out too much with the black upholstery and carpet.  Was thinking a satin black.
Is the light grey the proper factory color for the seat bottom and the hinges?
Thanks!
Thanks Ray.  Look forward to seeing your pics.  I already have the paint stripper and paint from other projects, so I'd rather just do them myself.  At this point the material cost would be $.0  and it would only take a few days to paint.  Most of that time is waiting for stuff to dry before moving on to the next stage..
Yes mark. I will try to post some pics. Powder coat them. quicker
Thanks Ray.  Your powder coating looked good.  I'm still pretty sure I'm going to go with black.
I need to drag my seat out and get some estimates to a few upholstery shops.  I haven't used an upholsterer for quite a long time, and need to find another one..
Check your cell phone
Moar fun..
After playing around with front wheel spacers, I ended up with a 10mm.  The 15x7 +11 Longchamps were fouling the coil over adjusters.  Funny thing is that I have effectively ended up with a 15x7 with a 0 offset now.
I'm going to be on the lookout for a pair of 15x6.5" or 15x6" Longchamps with a backspace of about 4" instead of 4.25" that I have now.
Anyway, it's about 2" more low in the front, and looks a LOT better, IMHO.  No rubbing anywhere, but I haven't driven it over any majorly big bumps.
It works, but still not a fan of wheel spacers though....
  • Like 3
Well, yet moar phun...
Back in April of 2017 right here on this thread, we had a lengthy discussion over my oil pan hitting the center link.  I also noted that the steering geometry looked very strange to me.  After replacing the oil pan, I kind of forgot about the steering issue.
As crazy as it sounds, it appears the wagon arrived here with a LHD center link.  Equally crazy is that a LHD link will actually bolt in and somewhat work, even though the correct geometry is out the window.  By adjusting the tie rod ends to equal length, and setting the camber to appx 0 degrees, the car would go straight down the road, but the steering felt very strange.
The good news is I located one from Japan, and it should be here in a few weeks.  I do have a factory idler arm in it, I only hope that it is a correct RHD version for my vehicle.
This one takes the title for strangest thing I have dealt with on this build...
I think we might have talked about this in Kelmo's "manure" thread, but here are my back seat hinges after a day and a half in my special paint remover.
I actually use a $6.00 per gallon grease remover I buy at Smart and Final.  If you let the parts soak in them for a couple of days, it takes spray paint right off.  Every time I use it, I'm always surprised how well it works.  These hinges were literally encased in spray paint that was really hard to remove.  I flipped the hinges and stuck them back in the coffee can to get the areas that didn't fit into the solution.  The stuff works great and is super cheap..
The very bad news is after confirming availability and price, I gave the seller my shipping address and heard nothing.  Three emails later, still nothing.  Found one in an Aussie junk yard at "heart attack" pricing, but I don't have a better alternative but to pay it...
I plan on ordering it tomorrow..
Huge leap of faith here, but everything I found online says this is exactly the centerlink I need for a RHD 510.  This is Japanese made, and found in Texas, of course..?
https://www.ebay.com/itm/TRW-ES2454-Steering-Center-Link-For-Datsun-1967-76-Bluebird-1973-77-Violet-RHD/183251070762?epid=749818556&hash=item2aaa9d6f2a%3Ag%3AcPUAAOSwkkNbD-HH&_sacat=0&_nkw=trw+2454&_from=R40&rt=nc&_trksid=m570.l1313
Edited by Duncan
  • Like 3
Health is okay.  Not getting any better at this point, but considering what other people my (our) age go through, I feel pretty damn lucky and grateful.  It can always be worse, and I am grateful for that.
Considering the steering geometry is in left field, (and not safe by any means) at least I can look at it and admire it for the time being?  My center link shipped today, and my friend in San Diego is coming up (along with all of his pullers) in the next week or two.  He's really good, and he has the chops to get it apart without destroying all my new stuff under there.  I pulled it all apart the first time knowing everything under there was going to get replaced.  It wasn't terribly pretty...
Truth be told, I'm really chomping at the bit to get this thing fixed and driveable.  I can't do much with it until it's driving.
Edited by Duncan
