Cool little mistake
(I remember seeing a thread with a bunch of people's custom steering wheels, but can't find it.)
So I was painting my steering wheel just to get it nicer than it was.
Primed, then used black rattle can; which didn't exactly turn out as well as I had hoped so I decided to prime it again and retry.
So that last coat of primer ended up not sticking and looking like this:
Which I rather like, so I'm keeping it that way, at least for a while.
I'd like to see what you guys have done with your steering wheels!
  • Replies 20
I tried painting my wheel, but a;lshrfapi9ugf!, kept getting fisheyes in the paint. So then I stripped it down, degreased everything again, and it still came out badly. Then I just stripped the paint back to its stock brushed black look. :mellow:
Both were Rustoleum, and it was around 52 degrees outside.
I don't know if that had anything to do with it but this is what happened.
I had little fisheyes in the black too, over the first coat of primer, but I like how it turned out, with the red rivets and all.
The weathered look is kinda neat though. :P
I painted the horn button black as well with no primer, and it came out pretty perfect, with very few imperfections.
You sprayed gloss black rustoleum over "dry" primer ... . no problem ........ . . but then you sprayed primer over "wet" gloss black .... . there's your problem
.... read the can.... it takes 24 hours for the gloss black to dry
To fully cure, but not for recoat.
Aww Ratsun.
Post #1: Hey guiz! I know I screwed something up, but look how neat it turned out!!
Post #2: Hey, that is sort of neat.
Post #3 - #34949874983798: AFTER CULMINATING THE UNICORN BLOOD INTO THE METEORITE METAL AND REINVENTING THE WHEEL AFTER BITCH SLAPPING THE CAVE MAN WHO FIRST CREATED THE FAILED FIRST MODEL, YOU WILL HAVE PERFECT PIN STRIPING!
Post #34949874983799: Lol
We have the same exact steering wheel! I just dont have the horn button for mine, im going to have to thing of something unique. Anyways heres mine before and after.
Before:
After:
My horn doesn't even work. :P
The PO wired the horn to a button and mounted it on the center console, so maybe that would work for you? Or at the very least something along the lines of that. Having to fill 3 holes in a center console is never fun.
