ViperGT Posted December 12, 2011 Report Share Posted December 12, 2011 wasnt sure were to post for a fast reply and yes i searched it, Will a 280z axel bolt up to a 510? Quote Link to comment
510kevin Posted December 12, 2011 Report Share Posted December 12, 2011 The rear diff? Or stub axles? Quote Link to comment
ViperGT Posted December 12, 2011 Author Report Share Posted December 12, 2011 stub axels is my main concern but will the diff fit? Quote Link to comment
510kevin Posted December 12, 2011 Report Share Posted December 12, 2011 The rear diff? Or stub axles? Nevermind, read your OxTHER THREAD <_< 280z should have an r180. Bolts right in. Quote Link to comment
ViperGT Posted December 12, 2011 Author Report Share Posted December 12, 2011 ok thanks and other thread? Quote Link to comment
banzai510(hainz) Posted December 12, 2011 Report Share Posted December 12, 2011 isnt a 280z a R200? half shafts are to long on a 510 or the Dust cover needs cut, soemthing needs to be done with them I think. R180s will work with the 510 half shafts but most R180s are the C cliptype and need the spider gear swapped in from a R160 then use the 510 half shafts Quote Link to comment
I'm BLUE Posted December 12, 2011 Report Share Posted December 12, 2011 Nevermind, read your OxTHER THREAD 280z should have an r180. Bolts right in. Stub Axles from a R-180 and R-200 are different R-200 Gearing Info here ( specifically z-cars ) ---> http://www.zhome.com...GearRatios.html 75-78 280z = R200 (typically) 70-73 240z = R180 Some rarer variations of r180 in later 280zx and 280z' models are recorded ,,, I have always seen R200's though ,,, I can't say for sure on 260z's now that I think about it :huh: ( tip of the tongue phenomenon ) ,,, It has been a long day lol isnt a 280z a R200? half shafts are to long on a 510 or the Dust cover needs cut, soemthing needs to be done with them I think. R180s will work with the 510 half shafts but most R180s are the C cliptype and need the spider gear swapped in from a R160 then use the 510 half shafts Yes ,,, 280z = R200 typically I am not famaliar with the conversion process to 510's ,,, I am a Z-guy Quote Link to comment
datzenmike Posted December 13, 2011 Report Share Posted December 13, 2011 ok thanks and other thread? http://community.ratsun.net/topic/38220-rear-axel-needed-for-4dr-510-72/page__pid__591759?do=findComment&comment=591759 Quote Link to comment
