ViperGT Posted December 12, 2011 Report Share Posted December 12, 2011 i broke an axel.... too many burnouts, and anyways i need an axel, left rear if it matters, and the part that bolts to the diff. Its my daily and the drive shaft shop (powertrain) said it would be too labor intensive to fix axel and that they didnt have the part that would bolt on the diff, they pulled on out but bolt holes were smaller and it looked like 1/4 the strength of the stock one and there was not enough steel to drill it out. So just let me know if any one has an axel and does a 280z axel bolt up? Link to comment
banzai510(hainz) Posted December 12, 2011 Report Share Posted December 12, 2011 dont do burn outs with a R160. axle is vauge? You mean half shaft? Or stub shaft? Maybe its just bad U joint? U live in the USA which is close But WHERE might be closer if I have the part. Link to comment
ViperGT Posted December 12, 2011 Author Report Share Posted December 12, 2011 dont do burn outs with a R160. axle is vauge? You mean half shaft? Or stub shaft? Maybe its just bad U joint? U live in the USA which is close But WHERE might be closer if I have the part. i mean the shaft that is between the hub that bolts to the wheel and the diff, The u joint got torn to pieces and the end of the axel were the u joint attaches got ripped up and im in long beach ca Link to comment
datzenmike Posted December 12, 2011 Report Share Posted December 12, 2011 So you're selling the broken one????:confused: Link to comment
fuzz's '71 510 Posted December 13, 2011 Report Share Posted December 13, 2011 Location might help with sellers being close by. Fuzz Link to comment
