az_rat210 Posted November 29, 2011 Report Share Posted November 29, 2011 I purchased a set of NEAPCO 1-0028 U-Joints to replace the Joints on my Staked Driveshaft. I wound up asking Precision Engineering to Press the one worn joint out and press in a new one. A good thing because the Joint that NEAPCO says fits Datsuns is 3.74 MM too short on the C-Clip. On the CAP it is 9.30 MM deep and to fit the clips the shop had to shave off approximately 3/16" of metal (3-4 mm) to allow the clips to fit. The actual depth needed is approx 12 MM. Quote Link to comment
ggzilla Posted November 29, 2011 Report Share Posted November 29, 2011 Nissan says they are not replaceable. Rockford Drive Line has replacement u-joints available to replace the staked in u-joints used on some of the B210 and the B310 cars. * Rockford 430-9 Quote Link to comment
