billair Posted November 20, 2011 Report Share Posted November 20, 2011 Hey all, I'm about to swap a good running L18 with a rebuilt L20 The 18 has an electronic distributor, fires right up after sitting for a while, my question is.... Will the electronic distributor from the 18 bolt up the 20 and work as it should. Just trying to plan ahead as I lay here waiting to proceed, any help much appreciated thanks Quote Link to comment
datzenmike Posted November 20, 2011 Report Share Posted November 20, 2011 Yes they are completely compatible as the EI dizzys only came on the L20Bs to begin with. Quote Link to comment
H5WAGON Posted November 20, 2011 Report Share Posted November 20, 2011 Will the firing order be 180 off/out, or is that when going in a L16? Or is my memory missing something?.. :huh: Quote Link to comment
datzenmike Posted November 21, 2011 Report Share Posted November 21, 2011 I'm assuming the oil pump/dizzy spindle was clocked to make the L20B dizzy work in the L18 so nothing was changed on it and should line up with the L20B spindle just fine. . Quote Link to comment
Pacific coast Datsun Posted November 21, 2011 Report Share Posted November 21, 2011 Make sure you use the same pedastal thats on the dist. now. Quote Link to comment
billair Posted November 21, 2011 Author Report Share Posted November 21, 2011 Make sure you use the same pedastal thats on the dist. now. will do ... thank you gentlemen Quote Link to comment
