My Datsun 1972 510 Ka24de along with some 1970 roadster mixed in
ViperGT
OK so i recently picked up this 1972 510 for 3500 with a fairly straight body in the rear, it needs fendors a hood and truck to be perfect... and i have issues with the KA but im attempting to have the guys at KA-T.org help me out.
http://www.ground-control-store.com/products/description.php/II=758/CA=27
the fronts already got a pair with 280 brakes, stainless lines and ive got the calipers and mounts for rear disk but not sure were to get rotors?
  • Replies 27
The ka will not idle, i fixed a vacuum leak on the plenum by installing a gasket and cleaning up the rtv and i sprayed carb cleaner around but no more vacuum leaks. It used to miss at idle not any more but its either super lean or super rich and ussualy it shakes and stalls when it goes lean, and at wot it spits fire out the back and misses hard, wont really rev past 4 or 5k, but when the engine isnt warmed up it runs quite well hesitates a little bit at wot and has a somewhat bad idle but much better than when its warmed up, Also has flat top pistons not that that would change much, and maf and tps are working correctly.
So i broke the u joint and part of the rear left axel on my 510 doing too many burnouts but i found replacements. Im adding rear disk brakes and i was also wondering if the diff from a 280zx 83' is any bigger/ better than my 510 diff. It doesnt have an LSD but do they sell inserts? Also was thinking about taking the whole rear suspension from the 83' 280zx and bolting it on my 510 eliminating the coil springs and using the 280 zx coilovers in place of the stock struck. I got the whole rear end and used KYB coilovers for $240 score!!!
Zfighters POS mexi truck with my rear end.
510..
  • 8 months later...
long time no update. got a build ka now in the works just got porting on head done. valve job should be done when i get my mis-matched intake valves from supertech. been cutting out rust here and there no patches yet tho lol just holes. got rear coilovers w/225s WAY to soft, hits bump stops under power around corners and then slides. Painted rear seat area/floor and trunk white, looks very good also installing new fuel pump. Roadster has been daily for a while, will be in for paint when 510 is running. Bad blinker issues, fuse pops as soon as i turn on the key, also blinker wiring under dash looks like its been played with pretty hard. PICS!!!
possibly looking at something like this to fit slicks...
removable front core support, very handy still have grinding and painting to do but i like it. still need FUNCTIONAL hood pins. dont hate
will probably cut more out to make room for a/c condenser, oil cooler, intercooler, and rad, Any one ever seen a 510 with radiator in trunk? im considering it. Pic ture of valves is as so: left stock, middle and right mismatching intake valves from supertech, 2 match, and 6 match.
I have other ideas for wider body as well will post soon!
looking at aem but also considering MS. I will be rocking the stockers until they break again. already gone through 2 N/A lol, and i didnt break any after i welded my diff. Also have an open R200 that im gonna swap in welded most likely just cant fork out that extra 1000 for a r200 lsd, and i didnt have any understear probelms with a welded diff but i also have no front sway bar at the moment.
