GreaseMonky Posted November 16, 2011 Report Share Posted November 16, 2011 I need a lower gear for on the track, right now I have 3.90, i need to get the rpms up higher, got any suggestions? Quote Link to comment
ggzilla Posted November 16, 2011 Report Share Posted November 16, 2011 If it's a wagon, go with a 4.875. Nissan Competition used to sell them. Quote Link to comment
datzenmike Posted November 16, 2011 Report Share Posted November 16, 2011 If a car.... with some work you can fit an R-180 in.This would be stronger anyway and you may have already done so. Find an '80- December '82 4x4 or any 720 4x4 before the Z24 motor was used. The front differential is 4.375 and being on a 4x4 has way less mileage than the rest of the truck. Early Pathfinders with 4 cylinders (rare) had 4.625 R-180s in the front. Quote Link to comment
GreaseMonky Posted November 16, 2011 Author Report Share Posted November 16, 2011 Its not a wagon Quote Link to comment
ggzilla Posted November 16, 2011 Report Share Posted November 16, 2011 The 610 cars for USA used the R160 differential (same as the 510). You can get a 4.625 for it, previously sold by Nissan Competition: 38100-22100 ... but they are rare... Quote Link to comment
GreaseMonky Posted November 16, 2011 Author Report Share Posted November 16, 2011 What do you think I can get for it that would be easy to find, I was thinking something like a 4.30, or so LSD dont matter much we all weld ours up since we only run on dirt, and its a straight track car Quote Link to comment
MicroMachinery Posted November 16, 2011 Report Share Posted November 16, 2011 Front diff from an 80-82' 720 4x4 like Mike said above. 4.375, low mileage, and if I'm not mistaken, just about a bolt in affair. On top of that, the r180 is alot stronger than the r160. Quote Link to comment
GreaseMonky Posted November 16, 2011 Author Report Share Posted November 16, 2011 ok i apreciate it guys, i will check into that, hopefully its not much of a mod, we are suppose to use stock for year make an model of car, but if i can use a stockl looking part, with out alot of mods to put it in, i think i can get away with that Quote Link to comment
datzenmike Posted November 16, 2011 Report Share Posted November 16, 2011 ok i apreciate it guys, i will check into that, hopefully its not much of a mod, we are suppose to use stock for year make an model of car, but if i can use a stockl looking part, with out alot of mods to put it in, i think i can get away with that I don't think the R-180/R-160 look much different from each other. Here is an R-180 from '81 720 that I sold to a guy from Vancouver for his dime. He really liked the 4.375 ratio and was planning to swap a Subby LSD into it. The newer ('80 on?) ones will have a K cast into the top. I corrected my previous post text to include the early '87-'89 WD-21 Pathfinder with the Z24i motor. They also have front differential with an R-180 but with 4.625 ratio. Quote Link to comment
GreaseMonky Posted November 16, 2011 Author Report Share Posted November 16, 2011 I don't think the R-180/R-160 look much different from each other. Here is an R-180 from '81 720 that I sold to a guy from Vancouver for his dime. He really liked the 4.375 ratio and was planning to swap a Subby LSD into it. The newer ('80 on?) ones will have a K cast into the top. I corrected my previous post text to include the early '87-'89 WD-21 Pathfinder with the Z24i motor. They also have front differential with an R-180 but with 4.625 ratio. So if the 4.375 isnt low enough i can try a pathy front diff? how much modifying do i need to do to put it in? I am trying to get rpms up so this cam i put in will work a little better, Quote Link to comment
datzenmike Posted November 16, 2011 Report Share Posted November 16, 2011 I have no Idea. The pathfinder has a funny solid axle tube on the pass side that bolts on. Sort of an extension. Just remove it and the 510 drive shaft to the wheel should bolt on. The thing is finding a Z24 Pathfinder (never seen one) '87 to '89 had only the R-180 with 4.625. After '89 only VG30 motors and a different front diff. Worst case is you could salvage the gears and swap into another R-180 case, but I believe they are the same. Quote Link to comment
GreaseMonky Posted November 16, 2011 Author Report Share Posted November 16, 2011 Ok how hard is it to put the r180 from a 720 in? Quote Link to comment
datzenmike Posted November 16, 2011 Report Share Posted November 16, 2011 You'll have to ask someone who has done it. Some rear ends have bolt on stubs (720) and some driveshafts just push in. Maybe all you do is pty the 720 stub axles out and slip the 510 stubs in?? Quote Link to comment
GreaseMonky Posted November 18, 2011 Author Report Share Posted November 18, 2011 I am going to look at some 720's today, is there going to be a sticker, or a tag that i am going to look for? Quote Link to comment
datzenmike Posted November 18, 2011 Report Share Posted November 18, 2011 For a 4.375 you will want to look for '80- to December '82 720 trucks. Check the door tag for the exact build date. Another clue is to look at the engine tag located under the pass side hood hinge on the inner fender. The one below is from an '81 KC 4x4 and if you look in the lower right (where pen is pointing) you'll find the axle ratio HF 43.... 43 stands for 4.375. The engine size is to the left side and the line above and says Z22. An L20B is also acceptable. Those marked Z24 will have a rear ratio marked 41 or a 4.11 ratio in the front. . Quote Link to comment
