hollywood7600 Posted November 14, 2011 Report Share Posted November 14, 2011 What type of alternator can I use for my 71, 521 pickup. Mine just went out, and was wonder if I could installed a new alternator with more amps. I need to know what years are compatible and if it will be easy to install as the original one. Thanxs Quote Link to comment
510kevin Posted November 14, 2011 Report Share Posted November 14, 2011 theres a few threads on this floating around here already. most of them include pretty detailed instructions for swapping an internally regulated alt in your truck theres actually quite a few upgraded alternators with good and bad points. all of them are fairly straight forward swaps, some with minimal bracket and/or electrical mods. there are internally regulated alternators from newer datsuns.(like early 80's cars and trucks) the saturn alt swap is fairly common, but requires a little work ka alternators from 240sx, hardbody etc quest minivan alts gm 1 wire (extra bracket work i believe) and i think some guys are running powermaster? aftermarket high output alternators. http://community.ratsun.net/topic/8924-alternater-swap-no-excuses-sticky/page__p__117287__hl__%2Balternator+%2Bswaps__fromsearch__1#entry117287 use the search function, can be really helpful. good luck and welcome to ratsun ;) Quote Link to comment
DanielC Posted November 14, 2011 Report Share Posted November 14, 2011 There are lots of threads, do some searching. But I will tell you this. I have a 521, that I ended up putting a 50 amp external regulator alternator on, many years ago, before IR alternators were common. I used the stock voltage regulator, it worked fine, and still does. Last year, I bought a parts truck, that need work, but will probably be a runner someday. It was missing an alternator, and I happened to have an IR regulated alternator, that came from some four cylinder L-engine. I put that alternator on the parts truck, and made the simple modification at the regulator plug. Two short wires, with 1/4 spade connectors, and the IR alternator works. If you go with an internal regulated alternator, you must leave the ground wire from the alternator frame to the inner fender well, where the stock voltage regulator was mounted. If the ground from the cab sheet metal to the alternator frame is lost, the electrical will try to ground through the throttle cable. This will melt the throttle cable outer housing, and destroy the throttle cable, and leave you with a throttle probably stuck open. Quote Link to comment
hollywood7600 Posted November 15, 2011 Author Report Share Posted November 15, 2011 Thanxs for all the info, i will do all the research. Thanks one more time for responding quick. Quote Link to comment
