whitney Posted November 13, 2011 Report Share Posted November 13, 2011 My alternator recently went out and i had replaced with a new one, as well as putting a new battery in my car. And now we can't get it to start. What happend was i was driving home one night when all my powerd stopped working but my car continued running, I drove another 20 miles to my house and the lights phased out. My dashboard lights froze in place while my headlights and brake lights were out. The next day we try jumping my car and it starts then dies because of not being warmed up. I left my car there and didn't drive it for a week. then we replaced the alternator and now my car will not start for anything. Leading up to my car dieing, when it did run whenever i came to a complete stop it would die and i would have to start it again. So it could be related to a gas intake issue? I am not sure. please help! Quote Link to comment
datzenmike Posted November 13, 2011 Report Share Posted November 13, 2011 You're saying you drove it and slowly the lights dimmed and went out (do not understand the dash lights froze in place) Are you sure that you installed an external regulated alternator? Your car needs this and there are internally regulated ones that could have been mistakenly sold to you. By 'not starting' do you mean it cranks over but won't start? Quote Link to comment
kdatsun610p Posted November 14, 2011 Report Share Posted November 14, 2011 Does the engine turn off when the lights started to dim? Quote Link to comment
zerow Posted November 15, 2011 Report Share Posted November 15, 2011 Have you checked your fusible link? Sounds like a corroded connection at the battery terminal or a blown fusible link altogether. Quote Link to comment
datsun 160J SSS Posted November 15, 2011 Report Share Posted November 15, 2011 bad main ground these tend to break off or the screw pulls out .also have seen the main wire plugs melt off the fues block Quote Link to comment
ggzilla Posted November 15, 2011 Report Share Posted November 15, 2011 Where's the car at (which town)? One of us could go with you to look at it and get it running again. Quote Link to comment
ehime Posted November 28, 2011 Report Share Posted November 28, 2011 ^ Ditto If the alternator IS bad, it would slowly shut the car down too though, I've the same issue with the battery not getting enough charge, and lights/etc slowly draining my system. It's exactly how you described it. Does the car crank over if you try "jumping" the battery? Have you tried bypassing your starter solenoid? (I do NOT recommend trying that more than once, you can serious fry some shit fast) Have you checked the fusible linkage? Quote Link to comment
420n620 Posted November 28, 2011 Report Share Posted November 28, 2011 just so U peeps know. whitney has NOT been on Ratsun since Nov 13 2011 01:02 <_< Quote Link to comment
datzenmike Posted November 28, 2011 Report Share Posted November 28, 2011 You're saying you drove it and slowly the lights dimmed and went out (do not understand the dash lights froze in place) Are you sure that you installed an external regulated alternator? Your car needs this and there are internally regulated ones that could have been mistakenly sold to you. By 'not starting' do you mean it cranks over but won't start? It was a very confused post anyway. Quote Link to comment
