ZackTheImpaler Posted October 11, 2011 Report Share Posted October 11, 2011 What have you guys use? I hear that there are alot that will fit in, and I was quoted nearly $300 to have mine rebuilt. Quote Link to comment
danfiveten Posted October 11, 2011 Report Share Posted October 11, 2011 Im intersted to know this stuff as well since my 411 will be home soon. Quote Link to comment
ZackTheImpaler Posted October 11, 2011 Author Report Share Posted October 11, 2011 I heard that a 520 would fit, but that seems like just as much of a long shot finding as a 411 Quote Link to comment
MikeRL411 Posted October 11, 2011 Report Share Posted October 11, 2011 Time for someone with the old Red Book or microfische to chime in with part numbers and listing of other vehicles that use the same assembly. By the way, just to set in proportion, when replacement assemblies were available [all too long age] they listed for $17 !!!! Quote Link to comment
erichwaslike Posted October 12, 2011 Report Share Posted October 12, 2011 do u still have the original? it can be rebuilt very easily. just some general tlc to it and u could have it back to normal. Quote Link to comment
ZackTheImpaler Posted October 12, 2011 Author Report Share Posted October 12, 2011 I do have the original still. I don't know anything about them, how would I rebuild it? do u still have the original? it can be rebuilt very easily. just some general tlc to it and u could have it back to normal. Quote Link to comment
MikeRL411 Posted October 12, 2011 Report Share Posted October 12, 2011 (edited) I do have the original still. I don't know anything about them, how would I rebuild it? It's just a miniature radiator. Assuming that the upper and lower tanks are OK and that the core has a leak [usually the case], take it to a radiator shop. A minor leak can be "plugged" with a solder fill on all sides of the pin hole, the real fix is to cut a custom core and solder onto the upper tank and lower tank with the on off valve. The labor charge is what makes it expensive. If it's the valve, somewhere on this site there is an extensive "how to rebuild your heater valve" discussion. Google is your friend on this site! Edited October 12, 2011 by MikeRL411 Quote Link to comment
ZackTheImpaler Posted October 15, 2011 Author Report Share Posted October 15, 2011 Radiator shop quoted me 300 buckaroos :S It's just a miniature radiator. Assuming that the upper and lower tanks are OK and that the core has a leak [usually the case], take it to a radiator shop. A minor leak can be "plugged" with a solder fill on all sides of the pin hole, the real fix is to cut a custom core and solder onto the upper tank and lower tank with the on off valve. The labor charge is what makes it expensive. If it's the valve, somewhere on this site there is an extensive "how to rebuild your heater valve" discussion. Google is your friend on this site! Quote Link to comment
