socaldatsun Posted September 30, 2011 Report Share Posted September 30, 2011 These calipers came with the truck ready for the beebani disc convesion but not sure if they will fit/work with the set up. Thanks *wow didn't know my camera off my itouch was that bad, I'll take better pictures tomorrow with the Nikon. Quote Link to comment
datzenmike Posted September 30, 2011 Report Share Posted September 30, 2011 If the top ones are twin piston then they are consistent with '86.5 to '92 D-21 VG30 2wd and 4wd front calipers. Also '78-'92 WD-21 Pathfinder The rears are close to the Pathfinder rear discs but the e brake is drum on them. . Quote Link to comment
mklotz70 Posted September 30, 2011 Report Share Posted September 30, 2011 the correct calipers/rotors for the rear dics setup should be Isuzu Trooper....'85ish? Quote Link to comment
socaldatsun Posted September 30, 2011 Author Report Share Posted September 30, 2011 I'll post better pictures tomorrow, just not sure if these will work with the brakets. If not I'll just sell them, plus i think they are incomplete no bolts or anything came with them. on the rear i already have rotors so I just need front rotors/calipers& lines off the 2002 honda passport and rear just need calipers and lines from the trooper. *is the info for the brakes correct?* I'll look up the year for the trooper in a sec. * 88-91 Isuzu Trooper, 89-93 Amigo for the rear set up Quote Link to comment
