datsunfreak Posted November 11, 2018 Author Report Share Posted November 11, 2018 On 11/9/2018 at 4:04 PM, datsunfreak said: Planning to take it out tomorrow morning (weather permitting) for an extended drive of at least 20 minutes And of course, this didn't happen. ? It was about 35 degrees when I got there and only warmed up to about 45-50. This cold snap is due to continue for the next few days, so I'm going to focus on getting the passenger seat installed this week, so hopefully I can put some miles on it next week. I would like to put at least 80-100 miles on it before it gets really cold. January/February here it is often in the 30s for the high, so... On 11/9/2018 at 8:25 PM, Duncan said: You'll probably find that as you put a few more miles on it, you'll be changing, fixing, and tweaking stuff as you go.. Most definitely. ? Link to comment
datzenmike Posted November 11, 2018 Report Share Posted November 11, 2018 On 11/4/2018 at 9:54 AM, datsunfreak said: Now if you know anything about 510 rear springs, the weird lever ratio it has means that to get a wheel rate of 200 pounds, you need a spring rate of about 800 pounds. And no one sells a 6" tall 800 pound spring. So I asked a friend who was a suspension engineer for a big automaker what would happen if you took a 12" long 400 pound spring and cut it in half? Would you then have two 6" long 800 pound springs? He said that it would work in theory, but in practice you won't know until you try it. So I did... ? Hyundai spring on the left, 12" spring cut in half on the right... I think I will trim a bit more off of it at some point, but I want to drive it a few more times to see if it "settles" any... Also considering going to a 450 or 500 if this isn't firm enough. On really tight turns the car seems to have a fair bit of body roll in the rear, but I don't know how it would do on a curvy road yet... The 510 control arms and springs are hinged forward of the axle so there is a mechanical advantage, like pinching a pair of pliers. The ratio is 3.8 to 1, so an 800 lbs/in spring will feel like only 210 at the axle. For 450 you need a 1,70 lbs./in spring, 500 is 1,900 lbs./in.... which is insanely hard. Even 510s only go up around 300 for racing. 250 would be 950 275................ 1.045 300................ 1,240 Maybe a roll bar for the back? before the ride becomes unbearable? Link to comment
datsunfreak Posted November 11, 2018 Author Report Share Posted November 11, 2018 (edited) Quote For 450 you need a 1,70 lbs./in spring, 500 is 1,900 lbs./in.... which is insanely hard. Even 510s only go up around 300 for racing. 250 would be 950 275................ 1.045 300................ 1,240 You may have misunderstood. I started with a 400 to get to this. I may also try starting with a 450 or 500. I have ZERO desire to end up at 450 or 500 wheel rate. ? Quote Maybe a roll bar for the back? before the ride becomes unbearable? This is being considered but I need more open road testing before deeming it necessary. I also fear it would hang far too low and get ripped off a dozen times. Seen it happen on 510s that aren't even this low. Edited November 11, 2018 by datsunfreak Link to comment
datsunfreak Posted November 17, 2018 Author Report Share Posted November 17, 2018 (edited) Finally got the passenger seat installed today... Drove it to the gas station, and then drove it to get some lunch, about 10 miles total. Only got it up to about 50mph, but it feels really nice. It seems to go around corners really well, and the spring rates are very even front to rear now. ? I need to get the wheels balanced and the driver's door panel reinstalled, then it will be "done". ? Edited November 17, 2018 by datsunfreak 3 Link to comment
datsunfreak Posted November 18, 2018 Author Report Share Posted November 18, 2018 Also after the longer test drive I discovered my steering wheel was crooked.... ? Took it off and realized I can't reclock it to the correct position, so I said fuck it and drilled new mounting holes. You can't see them behind the horn button anyway... ? Link to comment
KELMO Posted November 18, 2018 Report Share Posted November 18, 2018 I don't think either of my 1200's have a steering wheel that is properly clocked. I know the grey one for sure is not. Link to comment
datsunfreak Posted November 18, 2018 Author Report Share Posted November 18, 2018 13 minutes ago, KELMO said: I don't think either of my 1200's have a steering wheel that is properly clocked. This is a pet peeve of mine that makes me crazy, so I had to... ? And with a regular steering wheel (as in not quick release) it's way too easy to fix, so get on it. ? 1 Link to comment
KELMO Posted November 18, 2018 Report Share Posted November 18, 2018 Dude, you've met me. You know first hand I ain't that smart. 2 Link to comment
datsunfreak Posted November 18, 2018 Author Report Share Posted November 18, 2018 2 minutes ago, KELMO said: Dude, you've met me. You know first hand I ain't that smart. Well, let me man-splain the easy way to do it... Grab a couple of tools and head to a big empty parking lot. Loosen the big nut about half way off. Simultaneously wiggle and pull on the steering wheel until it pops off the spline. Push it back down just a bit. Drive the car until you have established what straight is. Slowly brake in as straight a line as possible. Pop the wheel off and recenter. Retighten the big nut. 1 Link to comment
KELMO Posted November 18, 2018 Report Share Posted November 18, 2018 I'll try this instead of a parking lot. 2 Link to comment
datsunfreak Posted November 18, 2018 Author Report Share Posted November 18, 2018 7 minutes ago, KELMO said: I'll try this instead of a parking lot. That works too. ? Link to comment
datsunfreak Posted November 21, 2018 Author Report Share Posted November 21, 2018 Got some plates for it today, hoping to get the registration done in the next week or so... 4 Link to comment
]2eDeYe Posted November 21, 2018 Report Share Posted November 21, 2018 Vintage plates are the best. ? 1 Link to comment
Duncan Posted November 21, 2018 Report Share Posted November 21, 2018 On 11/17/2018 at 5:38 PM, KELMO said: I don't think either of my 1200's have a steering wheel that is properly clocked. I know the grey one for sure is not. Mine is off by just a hair. One spline in either direction, and it's off by a R.C.H. either direction I go. It's kinda like "hangin' right" or "hangin' left" depending on the weather at the time... 1 Link to comment
datsunfreak Posted November 21, 2018 Author Report Share Posted November 21, 2018 5 hours ago, ]2eDeYe said: Vintage plates are the best. ? This will actually be my first time. I normally do personalized plates, or just regular ones. In Texas you can use original year plates if you have an "antique" registration. This does limit how often you can drive the car, but it's not like I'm going to use it as a daily, so... ? 1 Link to comment
datsunfreak Posted November 21, 2018 Author Report Share Posted November 21, 2018 3 hours ago, Duncan said: Mine is off by just a hair. One spline in either direction, and it's off by a R.C.H. either direction I go. That's fixable on the tie rods, though. ? 1 Link to comment
KELMO Posted November 22, 2018 Report Share Posted November 22, 2018 The "FYL" on the plate is just awesome. 1 Link to comment
datsunfreak Posted November 22, 2018 Author Report Share Posted November 22, 2018 11 hours ago, KELMO said: The "FYL" on the plate is just awesome. I thought so. ? While searching for plates to buy, I of course had another page open to urbandictionary.com just to be safe... Link to comment
Duncan Posted November 22, 2018 Report Share Posted November 22, 2018 (edited) 20 hours ago, datsunfreak said: That's fixable on the tie rods, though. ? With the uneven roads here, I have to hold it one way or the other to keep the car going straight in the lane, so it's not too big a deal. ? I also like the "FYL" plates, too. Nice touch. In California, our 70's-era plates here were a med blue background with yellow letters. That combo = "fugly". Edited November 22, 2018 by Duncan Link to comment
datsunfreak Posted December 2, 2018 Author Report Share Posted December 2, 2018 Put about 20 miles on it today and ended up just driving it to my house instead of back to the shop. The few little things it needs I can fix at home, and this means I can take it out more often to do shake down runs since I'm only at the shop twice a week and need to spend my time there more productively than just cruising around in my car... ? Definitely need to get the wheels balanced soon as over 55mph they vibrate a bit. Will probably do that in the next week or two. ? Also need to tune the carbs as it's a bit rich... And maybe change the thermostat since today it never got over 170F (it has a 160F thermostat in it)... Link to comment
datsunfreak Posted January 9, 2019 Author Report Share Posted January 9, 2019 Put another 20 miles on it this weekend and everything seems to be doing alright. Stopped for a photo op... 12 Link to comment
Draker Posted January 9, 2019 Report Share Posted January 9, 2019 need some of those mirrors. car looks great!! 1 Link to comment
datsunfreak Posted January 10, 2019 Author Report Share Posted January 10, 2019 Thanks! Every time I look at it, I just think it needs more low... ? 2 Link to comment
]2eDeYe Posted January 10, 2019 Report Share Posted January 10, 2019 That looks awesome. Maybe just a little lower lol 2 Link to comment
dukerollo Posted January 10, 2019 Report Share Posted January 10, 2019 I’m sure you mentioned it, but I don’t want to dig though the annals of this thread to find it... What kind of fender flares are you running. I hope you say cheap eBay ones because, well, I’m cheap. Link to comment
