Orange620 Posted September 22, 2011 Report Share Posted September 22, 2011 Has anyone ever seen a different/better option used instead of the plastic 620 steering column cover? I'd even consider relocating the ignition and flasher switches if there was something like a metal Roadster/Fairlady part that would fit or be made to fit, to cover the turn signal switch mechanism. Quote Link to comment
izzo Posted September 22, 2011 Report Share Posted September 22, 2011 double post failure Quote Link to comment
Orange620 Posted September 22, 2011 Author Report Share Posted September 22, 2011 double post failure Looking for the delete button. Any suggestions? Quote Link to comment
datzenmike Posted September 22, 2011 Report Share Posted September 22, 2011 I erased it for you. Anything would be totally custom and likely plastic anyway. Quote Link to comment
yello620 Posted September 22, 2011 Report Share Posted September 22, 2011 I have a couple of spare plastic ones i would be willing to sell. Never seen a metal one to fit a 620 though. Quote Link to comment
crackerjack69 Posted September 22, 2011 Report Share Posted September 22, 2011 The ignition switch easily relocates to the cig lighter spot, leaving just the flasher and blink switch. I've been looking into a way to cover the blink switch, I like the naked column and hate the stock clamshell. I'll be developing some ideas, and doing some JY research to find a final solution. So far my best concoction has been a theory regarding a fiberglass blink cover... Will continue brainstorming, this must be solved. Quote Link to comment
Orange620 Posted September 22, 2011 Author Report Share Posted September 22, 2011 The ignition switch easily relocates to the cig lighter spot, leaving just the flasher and blink switch. I've been looking into a way to cover the blink switch, I like the naked column and hate the stock clamshell. I'll be developing some ideas, and doing some JY research to find a final solution. So far my best concoction has been a theory regarding a fiberglass blink cover... Will continue brainstorming, this must be solved. Agree, the bare column looks fine, just need a cover behind the wheel for the blinker switch mechanicals. I'm going to see what I can do with a piece of 3 1/2" metal tube split lengthwise. Quote Link to comment
