rhabdo71 Posted September 20, 2011 Report Share Posted September 20, 2011 Hey guys, I'm new to this site and would really appreciate any help I can get from anyone. I recently bought a 1971 Datsun 1600 pick-up truck (521) and EVERYTHING is ORIGINAL. Got it from an elderly man who bought it brand new from the dealership. The carb is original but it's old and sticking; choking for air. I bought a NEW Weber 38 DGES to replace the old one. It stated it's Universal and would fit my truck? Can I use this on my truck which has a manual choke. The Weber has a electric choke connector on the side of the carb. Will I be able to just connect the fuel line,hoses and the accelerator cable and start it up? Or, will I have to do some minor modifications to use this carb. I will post pics tonight of the carb and my truck. Thanks any any info from anyone would be appreciated! Quote Link to comment
Wide14u Posted September 20, 2011 Report Share Posted September 20, 2011 that carb should work but if you had some pics up you would get a lot more input Quote Link to comment
Wide14u Posted September 20, 2011 Report Share Posted September 20, 2011 welcome to ratsun this place has the best people on it :D Quote Link to comment
rhabdo71 Posted September 20, 2011 Author Report Share Posted September 20, 2011 Thanks, pics are coming tonight when I get off from work Quote Link to comment
datzenmike Posted September 20, 2011 Report Share Posted September 20, 2011 It stated it's Universal and would fit my truck? Can I use this on my truck which has a manual choke. The Weber has a electric choke connector on the side of the carb. Will I be able to just connect the fuel line,hoses and the accelerator cable and start it up? Or, will I have to do some minor modifications to use this carb. I will post pics tonight of the carb and my truck. Thanks any any info from anyone would be appreciated! Some research should have been done here first before diving in. It's possible that the original carb could have been adjusted or rebuilt for $25. This is the best carb for economy and drivability. Up to a point a very slightly larger carb will give a bit more power but it's a trade off. It will be harder to live with. That's way too big a carb for an L16 motor. Bigger does not always make it faster or we would all have 1180 4bbl Hollys on our Datsuns. The carb should be sized to the motor it is on. Well to late for that now. You will need to connect the electric choke to a fuse that is ON when the key is in the run position. You may be able to remove the throttle linkage on the Hitachi and bolt onto the Weber. This will make connecting the cable up to it much easier. Usually an adapter plate comes with a 'universal fit' carb kit. Almost certainly you will need to make some mods to fine tune the swap. What are you doing for an air filter? Quote Link to comment
Wide14u Posted September 20, 2011 Report Share Posted September 20, 2011 a 38 is that much bigger then 3236 Quote Link to comment
MRocha Posted September 20, 2011 Report Share Posted September 20, 2011 welcome Quote Link to comment
rhabdo71 Posted September 20, 2011 Author Report Share Posted September 20, 2011 Thanks King Rat! What type of material and/or equipment would I need? And how would I rig this? Thanks Quote Link to comment
wayno Posted September 20, 2011 Report Share Posted September 20, 2011 Welcome to Ratsun If you can take the carb back and get the proper sized one, I would do it, engines run so much better set up correctly. Quote Link to comment
rhabdo71 Posted September 20, 2011 Author Report Share Posted September 20, 2011 Thank you ALL, Luckly, I do and I always buy things with a return and warranty back up. I think I will return it and exchange it for the Weber 32/36. One other question. Is it better to have a electric or manual choke? Thanks again. Quote Link to comment
wayno Posted September 20, 2011 Report Share Posted September 20, 2011 Thank you ALL, Luckly, I do and I always buy things with a return and warranty back up. I think I will return it and exchange it for the Weber 32/36. One other question. Is it better to have a electric or manual choke? Thanks again. The choke type is a personal preferance, if you know how to use a manual choke properly, then go for it, less to go wrong/set up, if you are unfamiliar with a manual choke, then I would go with a automatic choke. Manual chokes are old school, I am old school. Quote Link to comment
Big Schlink Posted September 20, 2011 Report Share Posted September 20, 2011 I love manual choking, and I'm not talking about what most of you are thinking. 1 Quote Link to comment
DanielC Posted September 20, 2011 Report Share Posted September 20, 2011 I am going to back up Datzenmike. I am a big fan of the OEM carb. I would try to get it working first. If you cannot, then consider an aftermarket carb. Quote Link to comment
Wide14u Posted September 20, 2011 Report Share Posted September 20, 2011 I love manual choking, and I'm not talking about what most of you are thinking. you would :rofl: Quote Link to comment
banzai510(hainz) Posted September 20, 2011 Report Share Posted September 20, 2011 I agree the stock carb is good if working ,Gowever they are almost 40 years old and once they go bad In my opinion I would do a weber 32/36 DGV %A as this is a manual choke version and the stock choke cable should fit. The kit will come with a adapter plate that fits on the stock manifold as the Weber carb spacing is bigger than the stock Hitachi spacing. also try it keep the gaskets intack so you can make new ones if you have to as outlines. As Datzenmike said the Hithachi linkage in back will fit on back of the weber. aslos in the kit should be a brass colored cable bracket holder for the accell cable. also depending on your set up you might need to rig a soft return spring. I seen soem good set up and some bad ones. olddatsuns.com the tech section! Quote Link to comment
rhabdo71 Posted September 20, 2011 Author Report Share Posted September 20, 2011 Hey Guys, I appreciate all the input so far. I have photos ready to go but having trouble pasting them to this Reply box. This may be a dumb question but does any one know how to put images in this box. I clicked on the "Insert Image" icon but it asks for a URL. I have my photos on my computer. Thanks. Quote Link to comment
henryhustler Posted September 20, 2011 Report Share Posted September 20, 2011 http://community.rat...e-photo-albums/ welcome to ratsun. Quote Link to comment
bilzbobaggins Posted September 21, 2011 Report Share Posted September 21, 2011 Cant wait to see your truck!!! Ive never ran a 38, but my 32/36 is plenty for my stock L16. I need to jet it down lower as she runs a bit rich! welcome to the most adictive site Jeff Quote Link to comment
rhabdo71 Posted September 21, 2011 Author Report Share Posted September 21, 2011 Does anyone know what the dimensions are for the 71' Datsun 521 front drums and where can I get new ones. Are they the same size as the rear drums? I found some drums on new datsun parts .com but think they are a little to much $$$ ($136 ea.) Quote Link to comment
wayno Posted September 21, 2011 Report Share Posted September 21, 2011 Does anyone know what the dimensions are for the 71' Datsun 521 front drums and where can I get new ones. Are they the same size as the rear drums? I found some drums on new datsun parts .com but think they are a little to much $$$ ($136 ea.) Sounds like a good time to upgrade to front disc brakes. Quote Link to comment
banzai510(hainz) Posted September 21, 2011 Report Share Posted September 21, 2011 Try Rockauto.com for some parts or importrp.com Quote Link to comment
rhabdo71 Posted September 23, 2011 Author Report Share Posted September 23, 2011 Do you know where I can get front disc kit? Also, do you know if the front drums are the same size as the rear drums? Thanks. Quote Link to comment
rhabdo71 Posted September 23, 2011 Author Report Share Posted September 23, 2011 Thanks Banzai for the websites. I'll check them out. Quote Link to comment
wayno Posted September 23, 2011 Report Share Posted September 23, 2011 Do you know where I can get front disc kit? Also, do you know if the front drums are the same size as the rear drums? Thanks. You can use stock wheels with this package. http://community.ratsun.net/topic/11459-disc-brake-kits-521520320620/page__view__findpost__p__152608__hl__mklotz70__fromsearch__1 Quote Link to comment
DAT510 Posted September 23, 2011 Report Share Posted September 23, 2011 if you haven't already installed the Weber, you need that long metal piece from the Hitachi and on my 510, the electric choke wire is different from the stock one the Weber is like this of course instead of female its male and Hitachi one is like this same as above male instead of female Quote Link to comment
