clutch fork help,please
I have been getting ready to stuff a clutch into my truck thats been setting for years. I have a "280 Z" 5 speed that I am using and need some help. The clutch fork has a hole in the Slave end,the slave rod passes right through it. What is happening or am I being really STOOPID?:
  • Replies 5
the fork with the hole I know was on the 521/510 series.
The treded rod went thru. There will be a threaded ball that goes with this as to adj the slop out of the slave cylinder throw.
The later slave cyl just had a rod comming out of the slave. The rod just was a rounded end that went to a Clutch fork (it just was cuped) No hole.
Most slave cylinders are the same for most L motors(521 had different) But just find a matching rod for it
To PhatDave
From your best buddy
Hainz!!!!!!!!!!!
