720 radio wiring
Zombro
When I got my 720 the radio power wires were stuck into the fuse panel for the 12V switched and for 12V constant.
I forgot to mark where they were originally.
Can someone tell me which fuses I can stick the wires into for the radio to work again.
OR tell me how you would wire it.
  • Replies 7
The switched power for the '84 720 radio is a Brown wire in the harness and comes from the 7th fuse (15 amp) over from the left side of the fuse box.
If you still have the remains of the radio plug on the harness...
Black/Blue stripe is ground
Red/Yellow and Red/Blue is for the lights
Light Green/Black and Light/Green is the RH speaker
Light Green and Light Green/Red is the LH speaker.
