521 Steering wheel
Thebandito
  • Replies 8
i just put a RAID dino wheel in my truck and it came with a RAID hub, supposedly it came off an old ford truck and the spline fit the 521 just perfect. FYI RAID and nardi stuff is the same bolt pattern so if you had a hub from one and the wheel of another they will bolt up.
to my knowledge you can buy any momo hub, nardi hub... etc. for an early Ford truck and it should be the same as mine fit perfect. i modded the hub a little so it fit closer to the dash as well.
just incase you'd like a different wheel than the default grant wheel or stock wheel thumbup1.gif
  • 1 month later...
