WTB 510 SSS air cleaner assembly for Hitachi dual carburetors
Please contact me if you have for sale an original 510SSS air cleaner assembly for Hitachi twin carburetors that are 38 mm.
I prefer to purchase an original airbox; however, I will also consider the purchase of custom aircleaners, as well.
I will also consider the purchase of airfilters.
Thank you.
  • Replies 4
The stock airbox will NOT fit in a 620. Here is a cheap alternative:
http://community.ratsun.net/topic/5294-su-air-cleaners-for-a-ratsun-price/
jun has used a similar setup in his 620, and has pictures to prove it:
http://community.ratsun.net/topic/20454-juns-71-510-wagon-and-72-620/page__st__500
Post #504
On the outside chance that you do get a line on the 510 SSS assemblies, these are the parts you need. Intake manifold, heat shield, fuel tubes,linkage and choke cable are extra.
#165200-22000 SSS Air Cleaner Assembly
#16546-22000 Replacement element
#46010-N0110 Single Brake Master Cylinder
#46255-21005 Brake Tube Connector [you are going from 2 brake line outlets to 1]
#47215-W6500 Master-Vac Plate.
http://community.rat...a-ratsun-price/
http://community.rat...0/page__st__500
Post #504
Thank you for your comments. I had viewed the excellent thread showing how to build custom air filter assemblies for su style carbs before I posted this thread. I am aware that it may not be possible to use the original air filter assembly for a 510 SSS in a 620 because of clearance issues. The brake booster is in the way. The master cylinder and the slave cylinder leave little room for air cleaners. Although I may not be able to use the original airbox for the 510 SSS in my 620, I would like to have one if for no other reason than for display.
Thank you for the info.
