hogboy52 Posted August 22, 2011 Report Share Posted August 22, 2011 ... This is some unknown scrap, looks like seat rail. It is 1+1/4 in. wide. Because the cam towers are so close to the valve springs. it can not be much wider. The "adjustable pivot" (bolt & two nuts) is 1+1/4 in. from the valve stem. Also needed is some flat metal to place under the cam heel. (Bad photo) This a mock-up. I don't feel like taking my motor apart just for pictures. The socket on top is the cam. The socket on the right is the valve spring. This is position one. Here is position two. IMPORTANT: using a straight handle like this will require unscrewing the ball adjusters from the head for clearance or a bend can be added to the handle. Considering how crude it looks it actually worked quite well. ... Quote Link to comment
Sealik Posted August 22, 2011 Report Share Posted August 22, 2011 Keepers were a bitch to remove? This worked good with stock spring heights...but.... not as well with taller springs Not that expensive...60 bucks....'you' could probably purchase it for 30 Kudos for improvising........ :thumbup: Quote Link to comment
Sealik Posted August 22, 2011 Report Share Posted August 22, 2011 As you can see here with the height of an uncompressed (taller) spring.....not much room under the cam Quote Link to comment
hogboy52 Posted August 22, 2011 Author Report Share Posted August 22, 2011 ... I had no problem with the retainers, I could jigger the cap around and the retainers would pop out with a strong magnet. The original problem was that the cam was too high above the springs to get a proper angle for levering the springs down. Taller springs would make it easier. Actually my photo is somewhat exaggerated on the length of the bolt necessary to get a good angle. I stuck that one in there just for the photo-op. What can be seen in the last pic of yours is how much the ball-end adjusters are in the way. They would need to be removed. This was strictly a one time job to replace the stem seals. The motor had been putting out an oil puff on start-up. I really don't need an extra tool lying about. ... Quote Link to comment
