oneslick720 Posted August 15, 2011 Report Share Posted August 15, 2011 So kinda got myself in a bind , After building a new frame for my 82 720 and robbing parts from my 85 and parts from the original 82 720 i have second guessed my measurement on the wheel base for the 82.. so short of the story is im trying to find a chassi/fram spec diagram or anything with the measurement on it thanks casey... Quote Link to comment
Sealik Posted August 15, 2011 Report Share Posted August 15, 2011 Width of the frame.....center to center? Wheel base or track? EDIT Assuming wheel base as stated.... :D Quote Link to comment
datzenmike Posted August 15, 2011 Report Share Posted August 15, 2011 '82 2wd standard cab short wheelbase: 2575mm (101.4") '82 2wd long wheelbase and King Cab: 2815mm (110.8") Quote Link to comment
Sealik Posted August 15, 2011 Report Share Posted August 15, 2011 '82 2wd standard cab short wheelbase: 2575mm (101.4") '82 2wd long wheelbase and King Cab: 2815mm (110.8") Yes....same as the 83+ years Quote Link to comment
oneslick720 Posted August 15, 2011 Author Report Share Posted August 15, 2011 yeah 101.4 is what i had down for my 86 but i know that the cab is 2" shorter on the 82 so then i started second guessing all my measurements and i have nothing to reference back to now and i was nervous when i started to set up for my rear links Quote Link to comment
datzenmike Posted August 15, 2011 Report Share Posted August 15, 2011 Hahaha... all 720 2wd and 4x4s have the same wheelbase for long/KC and short so either 101.4 or 110.8" Quote Link to comment
oneslick720 Posted August 15, 2011 Author Report Share Posted August 15, 2011 where did the 2" from the differnece in the cabs go? Quote Link to comment
oneslick720 Posted August 22, 2011 Author Report Share Posted August 22, 2011 am i the only one that knows about the 2 inches? or have i lost my mind cab mounts are the same but from the door to the back of the cab is 2, 2 1/2" shorter from my at to my 86 which would add extra space between bed to cab and offset the wheel in the center of the wheel well Quote Link to comment
wayno Posted August 22, 2011 Report Share Posted August 22, 2011 They made the cab slightly bigger, and the box slightly shorter. The 80-82 longbox is longer than the 83-86 longbox, I should know, I lengthened my 1980 720 frame so I could have a kingcab longbox truck, then I found out the later model boxes were shorter, needless to say there wasn't a good longbox 80-82 around, while the 83-86 longboxes were everywhere and perfect. All the shortbox frames are the same, all the longbox frames were the same, and the kingcab was on a longbox frame. All the kingcabs measurements remained the same from 1980-86. Quote Link to comment
oneslick720 Posted September 16, 2011 Author Report Share Posted September 16, 2011 thanks wayno thas what i was needing to know cause i will be using an 82 cab and a 86 bed and was really worried about my wheels centering in the wheel well Quote Link to comment
