610 street demon resurection
bonvo
  • Replies 2k
On 7/25/2021 at 3:42 AM, slowlearner said:
reason I mention it is because of what someone mentioned to me a while back. That being swapping coilovers straight in without any other mods can cause issues. The trailing arms around the shock mount on the 510 are boxed in (See 10:30, it's called the "Safari" mod.) It stops the shock mount on the arm from bending. I'm also told the upper shock mount isn't really designed to have a the whole weight of the back of the car on it. You can see his upper shock mounts are all seam welded and the mounts are built into the cage and braced together (See 10:04).
Anyhow, I know you're not building a rally car, but I thought you might like to see this. 🙂
Those are excellent mods for a rally car, but they are really unnecessary for a street car.
I agree that the scope of the cage and build on that car are way above what's needed for a street car.
I fit was me fitting coilovers (which I think are a great upgrade btw) for a street car, I'd do the this.
1. Safari mod on the trailing arms. You wouldn't even need to take them off the car to do so although it would help.
2. Plate the upper shock mount, add a brace from one side to the other and seam weld around the back wheel arches and shock towers.
It wouldn't be hard to do and no one would see the mods, but it would help the back of the car deal with the change in forces. That's just me though. It's his car and he's free to do what he thinks is best. 🙂
