zerow Posted October 6, 2008 Report Share Posted October 6, 2008 lol what do you mean bro you had the licence plate lights didnt you :P Yep, had them in my hand... long enough to toss them into the trunk of that sedan. But, on a lighter note, I did take the ENTIRE interior. :D Quote Link to comment
bonvo Posted October 6, 2008 Author Report Share Posted October 6, 2008 sickdrift: no i havent lowerd it yet i need to wait till i can afford the tools i have to reg smog and renew then insurence all with my next check money will be tight datzenmike: you know i never thought of that thats a good idea to consider when i repaint it thanks for the insperation Quote Link to comment
bonvo Posted October 6, 2008 Author Report Share Posted October 6, 2008 (edited) Yep, had them in my hand... long enough to toss them into the trunk of that sedan. But, on a lighter note, I did take the ENTIRE interior. :D damn oh well the hunt begins :P just somthing to keep my eyes peeled for thats all oh and i forgot i may be able to get a header soon :D with the head im working on getting from sickdrift it looks like my idea of a performance head for when i dont have to smog it is comming to life oh zerow ill send you some pics of how the housings turned out i cant beleve the results myself Edited October 6, 2008 by bonvo Quote Link to comment
Guest jaimesix Posted October 7, 2008 Report Share Posted October 7, 2008 Bonvo. There is a great product you can add to your radiator, "Water Wetter" by Redline. Sold at Pep Boys. My brother uses it in his autocross car, he does enthusiast autocrossing ( at an auto club.) for fun, and that product is great. I know it is no substitute for a proper fan, but it will help, fan or not. Check it out. http://www.redlineoil.com/products_coolant.asp Jaime._____________________________________________________ i feel stupid i know i posted things about my temp readings but i never posted pics and my conclution of the rabbit radiator ok here is a pic of what my temp gadge shows when i do anything over 40 mph and this is it if i sit at a light to long on a relativly hot day solution: i need a bigger fan :P but all in all when it has enough air flowing over it the car runs "cold blooded" i would recomned the rabbit radiator upgrade to ayone looking to use it as long as they use a good fan with it Quote Link to comment
zerow Posted November 1, 2008 Report Share Posted November 1, 2008 i feel stupid i know i posted things about my temp readings but i never posted pics and my conclution of the rabbit radiator ok here is a pic of what my temp gadge shows when i do anything over 40 mph and this is it if i sit at a light to long on a relativly hot day solution: i need a bigger fan :P but all in all when it has enough air flowing over it the car runs "cold blooded" i would recomned the rabbit radiator upgrade to ayone looking to use it as long as they use a good fan with it You know, I just noticed something: Did you take these pics back to back?? If so, why do you have more gas at a stop than when you were moving?? I will place my bet that you need to re-ground your instrument cluster. I need my Haynes book back to see what position is the ground wire on the circular connector (paging nbesheer with Haynes book, please, nbesheer with zerow's book, please) I know you went with the Rabbit radiator, but I wouldn't want this to be an instrumentation problem. Quote Link to comment
bonvo Posted November 1, 2008 Author Report Share Posted November 1, 2008 nope different times shit different days even its not an instrumentation problem that i can think of everything works (except that damn brake light its always on and the brakes work fine there is nothing wrong with them) i doubt it but could a bad ground cause that light to always stay on? Quote Link to comment
69FJWagon Posted November 1, 2008 Report Share Posted November 1, 2008 nope different times shit different days even its not an instrumentation problem that i can think of everything works (except that damn brake light its always on and the brakes work fine there is nothing wrong with them) i doubt it but could a bad ground cause that light to always stay on? Hey Bonvo I had the same problem on my first 510 tuned out to be the switch on the E brake was bad, see what happens if you mess with E brake try pushing in on the handle when its released Clayton Quote Link to comment
bonvo Posted November 1, 2008 Author Report Share Posted November 1, 2008 Hey Bonvo I had the same problem on my first 510 tuned out to be the switch on the E brake was bad, see what happens if you mess with E brake try pushing in on the handle when its released Clayton ill have to try that thanks for the idea man:thumbup: Quote Link to comment
bonvo Posted November 10, 2008 Author Report Share Posted November 10, 2008 this is the sterring wheel i want Quote Link to comment
Guest jaimesix Posted November 13, 2008 Report Share Posted November 13, 2008 Hey bro, how is it going?? Still not re connected to the net. I fired "Earthlink" for gross incompetence.:) Studying the market in order to avoid another fiasco, so my presence in the net will be sporadic untill reconnection. I will send you some pixes of my ride. Soon on the road. I am getting plenty of info and experience with my 610 suspension, I will relay it to you. Meanwhile, when enver posible, get a set of front 280ZX strut assemblies. Those bolt on to the 610 suspension. The benefit is the vented rotor and larger brake caliper. With a new spring perch welded on, you can add threaded sleeves that will render your suspension height adjustable. Keep in touch. Jaime.________________________________________________ Quote Link to comment
bonvo Posted November 13, 2008 Author Report Share Posted November 13, 2008 Hey bro, how is it going?? Still not re connected to the net. I fired "Earthlink" for gross incompetence.:) Studying the market in order to avoid another fiasco, so my presence in the net will be sporadic untill reconnection. I will send you some pixes of my ride. Soon on the road. I am getting plenty of info and experience with my 610 suspension, I will relay it to you. Meanwhile, when enver posible, get a set of front 280ZX strut assemblies. Those bolt on to the 610 suspension. The benefit is the vented rotor and larger brake caliper. With a new spring perch welded on, you can add threaded sleeves that will render your suspension height adjustable. Keep in touch. Jaime.________________________________________________ jaime have you looked into at&t for internet? thats whats here at the house and it works great. i look forward to pics of the car man thats for sure i was looking into a set of struts off a zx last time i was at the yard till i got to the front and they wanted $70 a peice:eek:i got to find a new yard near by Quote Link to comment
Guest jaimesix Posted November 13, 2008 Report Share Posted November 13, 2008 jaime have you looked into at&t for internet? thats whats here at the house and it works great. i look forward to pics of the car man thats for sure i was looking into a set of struts off a zx last time i was at the yard till i got to the front and they wanted $70 a peice:eek:i got to find a new yard near by Bonvo, do not forget Datsuns 810, those 810s have the same suspension as the Z cars, and I mean same. 610s have a "similar" suspension, but the 810s are identical. That means 810s have vented discs if not wrong. About internet, I called ATT, they do not service this area, because Verizon has a monopoly over here, no ATT on Verizon's area.:mad: Verizon is taking advantage and wants to charge too much.....I am investigating. Last time I jumped into a deal that went south, but through the Better Business Bureau, I was able to make them recant on their fabricated fees, so I am back to square one. Meanwhile I use the Library's PCs whenever posible, and have discovered a cool Internet Cafe around town. Cool. Not as cool as having the PC in my room, but it works. Late... Jaime._________________________________________________________ Quote Link to comment
Bugeye Posted November 13, 2008 Report Share Posted November 13, 2008 Bonvo, I found you a kick ass horn button for your car http://cgi.ebay.com/ebaymotors/TRANSFORMERS-DECEPTICON-STEERING-WHEEL-HORN-BUTTON_W0QQcmdZViewItemQQ_trkparmsZ72Q3a1205Q7c66Q3a2Q7c65Q3a12Q7c39Q3a1Q7c240Q3a1318QQ_trksidZp3286Q2ec0Q2em14QQhashZitem350121105434QQitemZ350121105434QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories damn, maybe if i would have read a few posts up..lol Quote Link to comment
Guest jaimesix Posted November 24, 2008 Report Share Posted November 24, 2008 Hey Bonvo!!!!, need an update too ( asked Zerow before...:) )..... we need the interesting stuff to remain current in this site, a lot of other things here take the attention away from the real interesting threads. I will bring my thread to life later on, my car is coming closer to be rideable...the closer I get, the more details hinder.....but it will come along!!! Jaime._______________________________________________________ Quote Link to comment
bonvo Posted November 24, 2008 Author Report Share Posted November 24, 2008 the car is comming along just gave her a full tune up shes running like a swiss watch still trying to arrange to lower it i was gonna get an el dizzy but the wanted $60 + a core charge at a junk yard i couldnt beleve it the sign said $20 for distributors money is tight right now so no big upgrades or anything Quote Link to comment
Guest jaimesix Posted November 25, 2008 Report Share Posted November 25, 2008 Hi. I hear you, money is tight, it is that time of the year plus the economic situation as it is. Will keep you posted on any parts coming along. Jaime._______________________________________________________ Quote Link to comment
bonvo Posted November 27, 2008 Author Report Share Posted November 27, 2008 cool man thanks for the looking out jamie Quote Link to comment
bonvo Posted December 4, 2008 Author Report Share Posted December 4, 2008 small update: this weekend im wiring up the fog lights i got with the nos front end Quote Link to comment
bonvo Posted December 6, 2008 Author Report Share Posted December 6, 2008 (edited) i went down to hayward to meet up with agentalpha he needed a ride to get a few things for his project and in exchange he gave me a few parts part number one is a rear ducktail spoiler for a z car its to narrow to use on the back of my 610 so i was looking at it and the thought came to me i can use this to get thw basic shape to make one for the rear of my car then take theis one flip it upside down and bam i have a spook front airdam :D its obviously not a perfect fit but its somthing i can work with im thinking cut it down the middle so the 2 halfs fit against the valance then make a filler pannel he also threw in a crome alison coil and mounting bracket then to top it the guy we met up with gave me an old school momo steering wheel its in rough shape but a little sanding and painting it will be trick havent decided if this is the wheel i will go with in the long run but for now it will work perfect and i wont have my sterring wheel bitting my hands anymore :D Edited December 6, 2008 by bonvo Quote Link to comment
Rubberman Posted December 6, 2008 Report Share Posted December 6, 2008 Bonvo, the spoiler idea looks good. Just a few sheets of fiber glass and some hairy fiber glass bondo and you can form it in on the ends. Show some pics of what ever you figure out. Quote Link to comment
bonvo Posted December 6, 2008 Author Report Share Posted December 6, 2008 well not only does it need to be formed at the ends it also needs to be formed closer to the valance hece my idea to cut it in half then glass the center section Quote Link to comment
rusty510 Posted December 6, 2008 Report Share Posted December 6, 2008 i think youre on to something with that spoiler idea. Quote Link to comment
Guest jaimesix Posted December 6, 2008 Report Share Posted December 6, 2008 Bonvo. Good ideas. Check this out, I just thought about it. At Orchard Supply Hardware Stores here in Southern Cal I have found nice "rubber sheets". They have Neoprene and also real full rubber. You could use these material(s) to make a "lip" on the top and bottom suerfaces where the spoiler meets the car's valance, making it a tight air free seal. Also on the sides, on those spoiler gaps, a piece of rubber cut to match that triangular shaped on each side extending on its end only so much as to cover the gap and rest on the valance . That Momo wheel is cool. Is it what it appears to be? wooden grip?? If so, it can be sanded and boat quality wooden finish/lacquer can be applied ( like boat wooden interiors, have that beautifull wooden glow.) The fins of the wheel can be repainted in black and you will have a cool, good looking and brand name class wheel. Nice stuff. Jaime.____________________________________________________ Quote Link to comment
bonvo Posted December 7, 2008 Author Report Share Posted December 7, 2008 i like that idea for filler pannels that could work out well and yeah i was planing on cleaning it up canding it down and repainting the spokes the wheel will look trick when done Quote Link to comment
bonvo Posted December 9, 2008 Author Report Share Posted December 9, 2008 fog lights are wired up and ready to rock (pics later tonight after it gets dark) Quote Link to comment
