Transmission differences
OK guys I've been searching the net and can't seem to find any definitive answers. But does anyone (Datzenmike maybe??) know if there are any major differences between a single cam engine transmission and the twin cam engine transmission?? I know physically they look identical except for a few sensor differences. But are there any differences in gear ratios? My reason for the questions is because I ended up destroying the input shaft on my tranny from my twin cam engine and was given a transmission from a single cam engine setup. It may be just me but the single cam transmission seems to be a bit slower or maybe just not as torquey as the trans from the twin cam. Am I just "thinking" they are different?? And how difficult is it to rebuild one of these transmissions?
  • Replies 12
You're killing me smalls, this should be in General Technical. Ratios are most likely different, other than that everything else should bolt up, but wait for Datzenmike, he may have more info.
dammit....my bad I musta clicked the wrong linky thing.....sorry.......do I need to go grab the "board of education" :no:
Not being a smartass ,,, Is your "Pilot Bearing" Good ? :unsure:
I assume by "destroying" you mean ,,, FUBAR yes ? ( Fawked Up Beyond Any Repair )
Tisk Tisk ,,, were you having some fun when you destroyed your tranny ? :D
Are you asking about the transmissions from KA-equipped Nissan trucks?
Single Cam
1990-1994 D21 Hardbody Pickup KA24E
1995-1997 D21U Hardbody Pickup KA24E
Twin Cam
1995-1997 D22U Hardbody Pickup KA24DE
1999- WD22 Pathfinder KA24DE
hehehehehe.....alright heres the story.....
Yes I have been raping the shit outta the truck..... :cool:. I assumed at first that my throw out bearing was going bad due to the fact that it was only making noise when the clutch was released. I didn't change it right away but figured I could get away with it for a little while. Well I took the truck for a 120 mile trip and on the way there the trans started to whine and howl really bad. I babied her back home and lifted her in the garage. I pull the plug on the trans and hmmm......only half a quart of fluid comes out :mad: what a freaking dumbass!!! I completely forgot to check the trans fluid when doing the swap....arrggh. Yes I know let the flaming begin.
But getting back to it I pulled the motor to change the "throw out bearing" and found a completely destroyed input shaft. I'm thinking possibly, maybe, coulda been from the lack of fluid hahahaha.
Single Cam
Twin Cam
Sorry wasn't clear on that one important piece of info.
It is a Twin cam DE from a 92 240sx as was the original transmission.
My replacement trans is from an unknown vehicle but was definitely from a single cam.
Happens to the best of us. I forgot to tighten one wheel and it came off on the way to Canby ... good thing I was only doing 60 mph at the time.
I'm not alone!!
lulz I kid.
the [240SX] single cam transmission seems to be a bit slower or maybe just not as torquey as the trans from the twin cam
Single Cam 12-valve
1988-1990 S13 240SX KA24E
1st- 3.321
2nd- 1.902
3rd- 1.308
4th- 1.000
5th- 0.759
Twin Cam 16-valve
1991-1993 S13 240SX KA24DE
1994-1998 S14 240SX KA24DE
1st- 3.321
2nd- 1.902
3rd- 1.308
4th- 1.000
5th- 0.759
So they are the same.
Single Cam 12-valve
1st- 3.321
2nd- 1.902
3rd- 1.308
4th- 1.000
5th- 0.759
Twin Cam 16-valve
1st- 3.321
2nd- 1.902
3rd- 1.308
4th- 1.000
5th- 0.759
Well that answers that question!! I guess its just me hahaha. Damn I can't blame the trans!!
