question i lowerd my 720
vw40life
  • Replies 1
and as i have been driving it around it has developed toe and camber all at the same the wheels look like the top sticking out thank you for any help out
Sounds more like an observation than a question. It hasn't developed this condition from driving it around. Lowering the 720 by turning the torsion bars down has caused this. You can add washer/spacers to the upper control arm spindle and shim it inward to draw the top of the wheel inward. Extra spacers may require using longer bolts now.
Any lowering or raising the vehicle ride height from the stock setting will also affect the toe in of the tires. Normally the tires point straight ahead and just ever so slightly inward. If you can see the tires pointing in or apart it needs adjusting.
