arrrrrr!!!!!!!!! hating life
JCR
how can a simple task be such a disaster
i simply wanted to change a thermostat
everything is fine but the darn thing was leaking
so i get a new gasket and try again
this time the inside bolt goes in and tightens up gets to a point and boom no more tension on the bolt..i start to undo it and it has tension tighten again and no tension
long story short the hole is stripped ...no more threads
now if it had been the outside hole i have seen it drilled through and bolted but the inside one no such luck
so i am looking for ideas or a new lower thermostat housing
thoughts on a heli (i think) coil
or thread cutter
thanks all
or maybe somebody has a housing ???
please let me know
  • Replies 8
took z-train idea
took the old housing
cut a head off a bolt and j-b welded the bolt in the hole were the striped out treads were
now I have a bolt sticking up
add thermo housing and a washer and nut
and done
like it love it and fixed it with parts on hand ....love improvisation
plus i bought another housing from a datsun enthusiast so i have a back up
plus tonight i got cracking on my mirrors
Mirror Pictures
these are crappy night shots
