fastdadd Posted March 12, 2012 Author Report Share Posted March 12, 2012 i just noticed that i never put a link to the truck before i bought it so i am putting here for reference http://community.ratsun.net/topic/1657-my-new-620/page__hl__bluemeanie Quote Link to comment
]2eDeYe Posted March 12, 2012 Report Share Posted March 12, 2012 Wow, you did a nice job on that driveshaft, trans and gas tank. :blink: Quote Link to comment
slodat Posted March 12, 2012 Report Share Posted March 12, 2012 What failed on the one piece driveline? Do you regret going one-piece? Quote Link to comment
fastdadd Posted March 13, 2012 Author Report Share Posted March 13, 2012 the u bo;t that holds the axle to the spring came loose and let the axle move and pulled the drive shaft out of the trans letting it flop around until it fell out as for the one piece no i dont regret it but if the carrier bearing had been there the rear u joint would have broke and not the trans Quote Link to comment
]2eDeYe Posted March 13, 2012 Report Share Posted March 13, 2012 as for the one piece no i dont regret it but if the carrier bearing had been there the rear u joint would have broke and not the trans Or you would have just shredded the carrier bearing and mount. I think you would have had issues either way. Quote Link to comment
fastdadd Posted March 21, 2012 Author Report Share Posted March 21, 2012 the trans, fuel tank and new axle bolts are in i will take the drive shaft into six states the week and have them make me a new one Quote Link to comment
fastdadd Posted April 8, 2012 Author Report Share Posted April 8, 2012 got tired of looking at it on jack stands so i put it on the ground then started it up and let it warm up....trans sounds good and no leaks from the fuel system now if that damn drive shaft would hurry up so i can start driving it again Quote Link to comment
fastdadd Posted May 7, 2012 Author Report Share Posted May 7, 2012 finaly got all the parts together and every thing is in the truck now i just need to put fluid in the trans and check everything one more time.....i will be glad to get past this and on to other things Quote Link to comment
fastdadd Posted May 8, 2012 Author Report Share Posted May 8, 2012 i took it for a short drive today. Feels good after work i will put the interior back together and take it for a little bit more of a drive......i is nice to have back an old friend Quote Link to comment
fastdadd Posted May 21, 2012 Author Report Share Posted May 21, 2012 when i took it out for the short test drive it lost on of the caps on a u-joint. so i picked up another one and put it in today then took it on that short drive. felt good. had to fix a pinched spedo cable. and this trans is really sloppy in third gear but i will get used to it. Quote Link to comment
converted_to_datsun Posted May 21, 2012 Report Share Posted May 21, 2012 I've seen your truck around town for years. It actually got me inspired to get my 620. I like the tan rising sun with the black. Quote Link to comment
fastdadd Posted August 25, 2012 Author Report Share Posted August 25, 2012 so at bluelake my starter released the smoke. i ordered a new one from rockauto and found this on my door step tuesday Quote Link to comment
fastdadd Posted May 26, 2013 Author Report Share Posted May 26, 2013 ok few years ago i made a deal with izzo for these wheels i was planing on getting rid of the rubber and putting on some new then back just before winter started i had a tire fail with no money for new rubber i put izzo wheels on the truck not happy with them but they get the job done then after today i like it better now but still not what i want 2 Quote Link to comment
fastdadd Posted June 11, 2015 Author Report Share Posted June 11, 2015 so i have been having trouble starting the truck in the mornings. I thought it was the starter turns out there is water in #4 cylinder. I took the head off to see what the head gasket looked like cant find the problem being as this is a 210 head i will go to canby and see if i can find a head if not i will send this to a shop and find the problem 2 Quote Link to comment
]2eDeYe Posted June 11, 2015 Report Share Posted June 11, 2015 That's a bummer. Quote Link to comment
fastdadd Posted June 12, 2015 Author Report Share Posted June 12, 2015 my fault i ignored the fact that the tstat wasnt working correctly and let it get hot......if canby comes through i will end up with a better one 2 Quote Link to comment
fastdadd Posted June 16, 2015 Author Report Share Posted June 16, 2015 picked up a head at canby. waiting till payday to get gasket set then start putting back together 2 Quote Link to comment
fastdadd Posted July 26, 2015 Author Report Share Posted July 26, 2015 putting the head on the truck yesterday went to do final torque and on bolt stripped. today i will take it apart and see about putting a helicoil in there......guess i will go do the breaks on the b. Quote Link to comment
cruznude Posted July 27, 2015 Report Share Posted July 27, 2015 got the 8-ball peeps mirrors finished up today These seats are bad ass! beleive it or not... I have same ones and color pattern in my kc. Quote Link to comment
fastdadd Posted July 27, 2015 Author Report Share Posted July 27, 2015 i like them they are comfortable...i took the head rest off Quote Link to comment
fastdadd Posted August 13, 2015 Author Report Share Posted August 13, 2015 the heli coil kit came in and now the head is on and all the bolts are tight. after work tomorrow i will start putting things back on 2 Quote Link to comment
Jester Posted August 13, 2015 Report Share Posted August 13, 2015 Glad to see an update man! Quote Link to comment
fastdadd Posted August 13, 2015 Author Report Share Posted August 13, 2015 its been running so good i haven't had to anything to it 1 Quote Link to comment
