fastdadd 79 kc 620
  • Replies 134
thanks it was a blast..i took some old gauge faces and scanned them into the computer the just played on photo shop till i got what i liked then print and glued...as for the lights they are green i might see if i can get a photo of later
  • 1 year later...
  • 3 weeks later...
  • 5 months later...
i know it has been a while since i updated this...
last night i was driving on 205 when the drive shaft fell out of my truck not sure how bad the damage is as it was to dark to see...i dont think it was a driveline failure maybe a ujoint
i will be headed out there today to tow i home
had the center bearing pressed on and when they went to do the u-joint on the farthest rear it bent the ear the holds the u-joint so now i am looking for another shaft
then i went under there for the first time since it happened and the tail piece for the trans is broken so now i am looking for that also
good new though was switching the tank over and the tank i got from eagle-adam is in very good shape super clean inside
