A new addition to the family
  • Replies 175
On my way to pick up a new gasket right now. I just dont want to put it back together without knowing what the problem is. My dumb ass should have gave it a leak down test or compression before I tore it apart.
you see a ton of smoke and you think the worst, happens to us all. im curious about the head too, though
  • 1 month later...
I really need a few things.
Grey left horn button with springs and screw. DONE
Long heater hose. Factory only I have a chopped up ghetto mess! DONE
Auto trans speedo gear. any idea at least on the part number? DONE.cable had been pulled on
Tail pipe. DONE JAN 2013
Battery hold down, I may go after market on this.
Any help is much appreciated and I have paypal.
Tail pipe.
Add left lower door hinge. Redbanner the one I got from you is for the right side. Do you happen to have the drivers side with the L stamped on the hinge? I'm willing to trade or buy with anyone.
  • 8 months later...
Growling from the water pump just got fixed. I wanted to put the factory fan back on but I didn't like the spacing and I couldn't get the bolts back in because of the offset with the radiator in the way. I also left the shorter bolts at pick and pull. So the metal fan is back on for now but I do have  the fan and spacer for a later installment.
The long spacer made the plastic fan basically touch the radiator and the short spacer looked too distant. On second look it probably would have been fine.
  • 1 year later...
So I got a few things done on the b210 this weekend. Nothing special but since I never see the car cause our daughter is always out with it I took the opportunity to play with it a little and take it to work a couple days seeing she's out of town.
I repainted the front bumper and grill.
