datzenmike Posted October 7, 2021 Report Share Posted October 7, 2021 3 hours ago, opalbeetle said: It's an EI distributor, so I am not worried about it at all. I left the ballast resistor there, but there is a wire bridging the posts to bypass the resistance (read how to do that in old DQ issues). Originally it was to keep things looking stock...clearly that doesn't matter anymore. Ha! It'll be a winter project to remove it and clean it all up. Of course there is the issue of building a LandCruiser this winter, so I might not get to it! I thought it was done correctly when I put it all back together. I kind of do things like that slowly as I am always a little nervous about messing that stuff up. That's perfect!! The EI distributor has a current limiting circuit so it can't draw more than needed through itself. Good going. Quote Link to comment
opalbeetle Posted October 19, 2021 Author Report Share Posted October 19, 2021 I made a dead pedal this past week. My legs are short...so this is WAY more comfortable! After using it, it could have been taller, but it still does the trick. I will put some traction tap on it when I get the time to get to the store to get some. Thanks for looking in. Quote Link to comment
datzenmike Posted October 19, 2021 Report Share Posted October 19, 2021 I think I managed something under the carpet, But yes the vastly improve things.. Quote Link to comment
